Removal of drawer of the of the kimball desk - Washing Machines
When was the Kimball 1021 made and what is the full description of the organ? Thank you!
archive.org/stream/OrganBlueBook-1985-1986.organforum.com/forums/showthread.php?2907-Kimball-Organ/OrganBlueBook1986-Pt.2#page/n65/mode/2up,.organservice.com/kimball/kimball.htm
Nov 09, 2017 | The Music
Need some information on a Kimball piano made in 1950 serial # 517474?
517XXX is a 1950 Kimball.
This site has some Kimball info and will do an appraisal for $20.
http://www.total-piano-care.com/kimball-pianos.html
Sep 13, 2017 | Music
I have and antique Kimball serial number is 197287 trying to find out the value of it
Kimball piano values vary based on age and condition; as of 2015, many uprights sell for $10,000 or more. Kimball is a well-known brand, and several of its antique pianos are considered highly collectible.
The Kimball Piano Company, based in Chicago, was one of the largest piano manufacturers in the world. At the turn of the century, Kimball built approximately 20,000 pianos annually. Kimball produced pianos under different brand names such as Hinze, Dunbar, Whitney and Harrison. Styles were influenced by Victorian, Greek Revival and Arts and Crafts architecture, and upright models were often available as player pianos. Kimball was sold to the Jasper American Corporation in 1959, and its pianos were discontinued in 1996.
Apr 08, 2017 | The Music
How to remove center desk drawer
Some drawers have slides that have latches that have to be manually depressed simultaneously, in ordert to remove the center drawer. Look at the slides and see if there is a button, or possibly a machined strip of metal, that releases a latch that keeps the drawer from falling off the end of the slide.
Sep 17, 2017 | Hal Leonard Music
H08882ROTX sei lattice
The drawer was very hard to place in the slider runners, took 20 mins to get it in without it locking and getting stuck. Please note the small grayish tabs in side both slider runners, very hard to press theses tabs and see them but these tabs do release the drawer from being locked when you only have it half way in the slot it goes in.
Mar 08, 2013 | Southern Enterprises Lattice 48 in....
What is an executive desk?
An executive desk has a wide flat surface and drawers on the sides. These desks are great for people who need a lot of work space. They are most commonly made from wood (cherry and mahogany).
Aug 15, 2012 | Furniture
What is a u-shaped desk?
A u-shaped desk isactually very similar to l-shaped desk (corner desk), main difference beingthat it's shaped like the letter u. Like the l-shaped desk, it is meant to saveup work space.
Jul 25, 2012 | Furniture
Hi, I have received as a gift an adjustable keyboard manager, but there is no notice in the box and i have no idea of how to install it. Could you please send me the notice, in french rather than in...
Hello Sophie,
First, its probably best not to put your email address on this or any other web site which is similar, its like broadcasting it to the world, you could end up with loads of junk emails.
I couldn't find a manual for you but did find their website:-
http://www.fellowes.com/fellowes/site/support/support_contact.aspx?loc=top
With this contact number if you're in the USA
For Keyboards and Mice
1-888-335-8324
Contact Customer Support
Also, this review on a shopping website, with luck it should help you out.:-
"They come as a kit that needs to be installed under your desk with the supplied hardward. You will need a #2 Phillips screwdriver and a 3/32 Inch drill bit and drill (for the screw pilot holes under the desk) to install.
Installation is very easy and straightforward using the supplied paper template. Be careful to allow for space on the side (right side if right handed) so you can push the drawer under the desk with the keyboard shelf extended. You will need a second person to hold the drawer in place as you put in (at least) two of the screws to hold the unit up under the desk while you install the rest of the screws (8 total).
The keyboard drawer is robust enough for normal use. I used to support trading rooms on Wall Street and it's not robust enough for one of those gorillas to whack on. For normal mortals, it should be fine.
The keyboard drawer is fairly attractive and very functional.
The keyboard drawer fits most mid sized keyboards and includes an adjustable clamp on the inner edge to keep the keyboard from sliding forward. This clamp isn't really necessary as the keyboards do a pretty good job of staying put on the ridged drawer surface.
The clamp is held in place with plastic ears, which you can bend slightly to remove the clamp entirely if you have a large keyboard. On one of our drawers I have a Logitech Wave. With it's own plam rest, it's too big for the drawer with the clamp - so I removed the clamp and it works great. With the drawer's plam rest and the keyboard's, I have a nice wide place to rest my wrists.
The mouse shelf is just a touch smaller than a typical mouse pad, but is more than adequately sized. You do need to leave a little gap on the inner edge of the mousepad if you use one for clearance with the slider. This allows you to retract the drawer".
Jan 16, 2011 | Fellowes Keyboard drawer with retractable...
Desk drawer: can't full close drawer'' waterloo bearing glides
Just a guess, try pulling the track out of the box,onto the drawer
Mar 30, 2009 | Omega Waterloo Wi 1511 'waterloo 41 11...
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
