Question about Toshiba 32BV700B 32 in. LCD HDTV
How do i reset toshiba 32BV700B tv
I think I interrupted the installation and now I am left with a blue screen saying no signal? can you help please
3 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Posted on Feb 20, 2009
SOURCE: Just purchased a Toshiba 32BV700B
try 1191
Posted on Sep 29, 2010
Colour loss
Try a reset to this set and check. If it do not help you, contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 04, 2015 | Toshiba 32BV700B 32 in. LCD HDTV
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Have purchased new 37" toshiba.
Check the lead from the lounge to the bedroom is connected correctly. The blue screen means no signal.
Jan 01, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
How cani do to reset my ti89 titanium, if it has a message that say installation in progres do not interrupt,
Press and hold the 2ND, left-arrow, and right-arrow keys, then press and release the ON key.
If this doesn't reset the TI-89, please respond to this post and we can go on to the next step.
Dec 03, 2010 | Texas Instruments Office Equipment &...
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
Apr 16, 2010 | Toshiba 37AV500U 37 in. LCD TV
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 28, 2008 | Toshiba 43H70 43" Rear Projection...
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Toshiba 32BV700B 32 in. LCD HDTV Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
