Ms-6541 ver 2.1 mobo pin connector
Hello I need to know HDD led, Power led, Power Sw, Reset Sw and also for the usb connectors configuration(F_P1) for the Ms-6541 ver 2.1 This is torturing me a long time now, Thanks in advance!
2 Suggested Answers
ghost2233
  • 3606 Answers
SOURCE: Ms-6541 ver 2.1 mobo pin connector
Hello this should be the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97106&prodTypeId=12454&prodSeriesId=96284&swLang=13&taskId=135&swEnvOID=1093
The front panel looks like this:
d450e023-b94a-4bba-87c8-871096a37704.gifF_P1 PinOut
17 15 13 11 9 7 5 3 1
18 16 null 12 10 8 6 4 2
SHORT:
HDD led op 1/3
Power led op 2/4
Power Sw op 6/8
Reset Sw op 5/7
Here is also the manual:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&locale=en_US&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316609
The usb connector looks like this:
e3c82873-b0a1-49b3-91f4-548ca5550428.jpgIts basicly just to insert the black connector in it.
Best of luck
Posted on Jul 16, 2013
SHORT:
HDD led op 1/3
Power led op 2/4
Power Sw op 6/8
Reset Sw op 5/7
Best of luck
Jul 16, 2013 | Computers & Internet
How to & where to connect Power led + - /power sw/reset sw/HDD led
Get the user manual here: User Guide
Chapter 2 Page 17.
The plugs just fit on to little pins in the bottom corner of the board.
If you connect them and hard drive indicator light on the front of the case does not come on then you need to swap the 2 connectors around.
It's an led which has to be connected the correct way to work.
Same goes for the power led on the front of the case.
Jan 26, 2012 | MSI MS-6378 Motherboard
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Woule like the pin location for power & leds on F-P1 socket
The corner of the motherboard "diagonally-opposite" of the keyboard/mouse PS/2-port connectors has a grid of gold pins. One pair of pins is labelled 'PWR'.
One pair of pins is labelled 'RST SW' ("Reset Switch").
Another pair of pins is labelled 'PWR LED'.
Another pair of pins is labelled 'HDD LED'.
Jan 10, 2011 | Computers & Internet
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Simple pinout help
Front Panel Header pin assignments as follows:
Pins 2 + 4 = Power Led
Pins 6 + 8 = Power Switch
Pins 12 + 14 = LAN Activity Led
Pins 1 + 3 = HDD Led
Pins 5 + 7 = Reset Switch
Pin 9 = +5v
Pins 11 + 13 = ODD Led
Pin formation is as below with no pin in position 10.
2 4 6 8 10 12 14
1 3 5 7 9 11 13
You will probably need to extend the Front Panel connector cable to reach the header pins on a replacement motherboard - I did this with 2 x N76HL 10 pin extension cables (male to female) from Maplin.
Mar 26, 2009 | Computers & Internet
Configuration
Hi
The wires that read +5 -d +d and ground those are USB connectors each usb connector will have 4 wires, +5 -d +d and ground so that goes to usb pins.
The sw must be power switch
The HDD led is the load light
Reset is the reset button
Power led is the front power light
SPK is the speaker / beeper.
Can you tell me the brand and model of the motherboard? They are documented in the user manual. but generally in the bottom right corner of the motherboard you have the connectors for the leds and buttons, its all written into the motherboard with small white text. but I can get clear instructions from the user manual for you.
You can look for the motherboard details between the expansion slots and between the cpu and memory.
Thanks,
Ekse
Feb 03, 2009 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Computers & Internet Logo
David Payne
David Payne
