Question about Home
Jacuzzi toilet HF20959
Less than 2 years old. Running all the time. Sometimes needs flushx2. Needs all new tank parts I think?
2 Suggested Answers
  • 100 Answers
SOURCE: need parts for a 30 year old jacuzzi toilet
Depending on what the innards look like, you can spend $15 at a home center like Home Depot for a toilet replacement parts kit. They're easy to install (about 30 minutes) and fix most common toilet issues.
If this won't work you might need to contact a plumbing supply company in your area. You'd be surprised what they have in inventory....
Posted on Jul 27, 2010
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
Jacuzzi espirit less than 1 year old, toilet runs and occassionally makes whisting noise. Sometimes it does not run - there is no pattern to what causes it to run or not run. This started suddently,...
Your symptoms point to a faulty "fill valve" (the piece with the float adjustment), and is most commonly caused by small particles caught inside from normal use or a mineral build up. To save time and energy i recommend you replace it with a Lavelle "Quiet Fill" fill valve available at most hardware or plumbing stores or online. They come with very easy to follow install instructions.
Aug 08, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Need parts for a 30 year old jacuzzi toilet
Jul 23, 2010 | Jacuzzi Home
We have a Jacuzzi X532 toilet. Can't get the water to stop running into the bowl, causing excess water usuage and stains intoilet bowl. This started about two weeks ago. Have this toilet approx. 3-4...
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
Jul 19, 2010 | Jacuzzi Home
We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
Jun 01, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
Apr 07, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Need to replace all the parts inside the tank of Jacuzzi toilet
Had a simular problum.
For about $130 you can have a 1.6 LF new in box and start saving water.
Hope this tip helps.
R/
David
Jan 22, 2010 | Jacuzzi Bath Maxima EL61 959 White...
We have american standard toilet model 4260 that runs all the time. have replaced seal twice. toilet is only 2 1/2 years old. what do we need to replace?
if it doesn't fill, it's your flapper, if your tank is full then you'll need to adjust the float. take a look on amazon for those 2 parts, and read into reviews. here: Modern Shower Doors at Amazing Prices. cheers
Sep 19, 2009 | Home
Home Logo
62 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
