Question about Mr. Coffee MRCTB Coffee Maker
I have a Mr Coffee MRCTB and it does not work
The coffee maker is not working and I do not have any repair or user manuals. After pouring the water in there it just sits there and does nothing
  • sherylj45 Sep 28, 2008
    I kept adding water until I put in a pot and it finally started brewing. But it is leaking from the bottom.
    New Friend:
You don't. It stays in there inside the heating tank. When you put in cold water, it pushes out the already-hot water. Every year or so, you need to clean it out, or have someone do it for you. I just cleaned about a half inch of gunk out of one we have had at the fire station for about 10 years. Never knew we were supposed to clean it out...yuk. Tastes better now. Clean as a whistle! Also had to replace an overheat safety switch, $8.00 on-line.
Posted on Jan 06, 2010
  • 1 more comment
  • Frank Jan 18, 2012
    We have the same problem here with the safety switch. I tried to search for it on line but could not find it. Where did you find yours?
  • Kipp Sep 25, 2012
    How did you clean it? Did you remove the back cover? Of course it says "no user servicable parts" but that is probably to support their service centers. Please let me know. Thank you
  • Kipp Sep 25, 2012
    How did you clean it? Did you remove the back cover? Of course it says "no user servicable parts" but that is probably to support their service centers. Please let me know. Thank you.
    New Friend:
I believe this maker works of the simple act of water in and water out. Reservoir holds about 2 pots worth of water to stay warm. Once water is poured in the hot water will be pushed out. You need to make sure the reservoir is full, once full initial warm up is around 5 minutes or so, thermostat will cycle the element to its set temp. Fill your pot - pour - put empty pot under fast or you will make a mess very fast because it doesn't take long for the water to pour out.. good luck
Posted on Feb 28, 2015
Okay, question. It does take quite a bit of water to get it ging. But, when you are all finished using it how do you get the extra water out of it?
Posted on Nov 05, 2008
Stupid question, but did you pour enough water in? It took a LOT of water before it finally started brewing.
Posted on Apr 26, 2008
I have one also. I just traced it down to a bad thermostat control. I have yet to figure out how to replace the thermostat. The problem is the thermostat stops heating the water before the water gets hot enough to be ejected over the coffee grounds.
Posted on Sep 16, 2007
SOURCE:
I have a mr coffee commercial coffee maker mod # mrctb when you put the water in the top does it start to drip into the pot right off
Hello, larry
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 09, 2011 | Mr. Coffee MRCTB Coffee Maker
THE MR. COFFEE COMMERCIAL COFFEE BREWER MODEL MRCTB. IT DOESN'T HAVE ANY LABEL. MY QUESTION IS JUST NEED TO KNOW IF I CAN USE THIS IN 110 V OR 220 V. SINCE IT IS COMMERCIAL.
Hope you can help. Water runs though pot but the water is not hot whatsoever. Heating element burned out?
Commercial Brewer 8543
Apr 20, 2010 | Bloomfield 8543 Coffee Maker
Where can I get an operations manual
I doubt that you can get any kind of repair manual. Mr. Coffee should make regular manuals available at their website. Go to the support section.
Jun 01, 2009 | Mr. Coffee MRCTB Coffee Maker
How do I program my Mr. Coffee ISTX95
I am sure abut this but most coffee maker work by pouring the amount of coffee you like to make.If it's a automatic then you have to put the coffee in it and pour the water also, then set the time you want it to start.Other wise just pour in after you put the coffee in and turn the switch on.
Mar 15, 2009 | Mr. Coffee ISTX95
Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
MRCTB Parts
High limit switch is bad. Where can I get a replacement?
Sep 23, 2008 | Mr. Coffee MRCTB Coffee Maker
The coffee could be hotter
Clean it. Use the manufacturer procedure. If that doesn't work, you can obtain a new thermostatic button. Outlet temp for most coffee makers is 180 F.
Mar 15, 2008 | Mr. Coffee MRCTB Coffee Maker
Where to buy paper filters? 10 - 12 cup are to small
MRCA8E is the discontinued filters for the MRCTB brewer. I'm on the hunt for suitable filters too....
Dec 06, 2006 | Mr. Coffee MRCTB Coffee Maker
Mr. Coffee MRCTB Coffee Maker Logo
1,586 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Pierre Laplante
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
