Question about Plantronics Savi W720 Multi-Device Wireless Headset System - US
Plantronics savi w720 headset keeps cutting out
My headset keeps "disconnecting" during use. I have to re-hit the connect button during calls. this happens every 1-2 minutes.
SOURCE: connection lost between Plantronics 510 Voyager and blackberry
I ave exactley the same problem on my Samsung sgh g600
Posted on Oct 07, 2008
  • 34 Answers
SOURCE: Pairing LG Shne cu720 to Plantronics Explorer 220
Try holding down the button on head set untill the phone reconizes
Posted on Jan 03, 2009
keekus
  • 83 Answers
SOURCE: Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Posted on Jul 18, 2009
  • 903 Answers
SOURCE: Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Posted on Oct 14, 2010
SOURCE: plantronics explorer 232, connected but no sound through headset
I had to power off my cell phone and then power it back on. That solved my issue.
Posted on Jun 02, 2011
I want to buy a wireless headset please suggest me a good one ?
The Savi W745 is a headset based upon Digital Signal Processing Technology launched by Plantronics. Plantronics Savi W745 has an excellent NC (Noise Cancelling) microphone having up to 3 different styles. This headset has a talk-time period of up to 7 hours and can optimized for Avaya, Skype etc and a 350' Bluetooth range connectivity.
May 23, 2017 | The Computers & Internet
How do I auto answer using Plantronics Headset (Savi W740) on a Mitel 4250 Phone?
Plantronics makes an adjunct device that attaches to the telephone base (Velcro) and can lift the handset when the button on your headset is pressed. Unfortunately that's the only way to directly integrate the Plantronics (or any other brand) headsets with the Mitel 4XXX series phone. This handset lifter is actually bundled with some of the SAVI headsets, depending on the actual model you get. Separately it's about an additional $50 option. I recall the Plantronics part number is HL-10. Hope this helps.
Jun 19, 2014 | Mitel Lands Phones
My m100 bluetooth always calls the wrong person.
Plantronics M100 always calls the wrong person:
Unfortunately this is a common occurrence. We say one name and it says, "did you say..." something totally different. I think that most of us has had that experience. The Bluetooth headsets that have a longer "boom" type mic will pick up your voice better and have a better chance at hearing your voice properly the first time. Models like the Plantronics Voyager Pro+ and the WG100/B have a boom type microphone. The WG100/B also includes a UBS Bluetooth adapter so it can be used on a pc.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/computer-mobile/wg100-b-savi-go-wireless-headset-mobile-computer.html
Good luck from Headsets Direct - 800-914-7996.
Aug 04, 2011 | Plantronics M100 Bluetooth Headset
Morning, my headset will put call on hold then i have to hit the "headset" button again on my phone to bring caller back
The CS70 headset only has the ability to mute a call. If you're phone is being put on hold when using the unit, you need to check and see how everything is configured. The user guide below will help you make sure everything is connected correctly.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Mar 28, 2011 | Plantronics CS70 Wireless Headset
My headset keeps cutting over to "voice control"
I would suggest resetting the headset and see if that will take care of the problem. Here are the reset instructions: While plugging in the AC charger, hold the power/pair button.
The headphones will show a solid red or blue light when they have been successfully reset.
Below is the link for the Backbeat User's Guide for more information.
Plantronics Backbeat User's Guide
Feb 19, 2011 | Plantronics Backbeat 903 Bluetooth...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Incoming calls don't connect easily when I hit the button on plan
Try deleting the headset from your phone, turn phone off for about 45 seconds and them turn it back on. Now try repairing headset to your phone. See if this will help with the problem.
Below is a link to the 300 Series User's Guide for more information:
Plantronics Explorer 300 Series User's Guide
Apr 04, 2009 | Plantronics Explorer 330 Headset
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
I disconnect from a call; Plantronics Explorer powers down
When you hang up from calls you are holding in the button for more than 2 seconds...This is way too long and it shuts off the headset. When you hang up, all you have to do is press the button quickly, until it clicks, and the call is disconnected. Anything more than a second or two will turn off the headset, as explained in the manual. Holding it in when a call comes in will make the phone "ignore" the incoming call. Again, all you need is a quick push of the button until it "clicks" will answer the call, the same as hanging it up. I hope this helps you!
Jan 29, 2008 | Plantronics Explorer 340 Wireless Headset
Plantronics Savi W720 Multi-Device Wireless Headset System - US Logo
656 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
