Question about Plumbing
Remove cartrage from 112.18.1 FAUCET
IT IS LEAKING AND NEED TO FIX HOW DO I GET IT OUT
2 Suggested Answers
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
Hot water tap leaking what can i do
That is a simple fix - you need to replace the cartridge that is in the faucet handle. however, each manufacturer is different. NOTE sometimes you need a specially designed removal and puller tool. I found this out the hard way. I had a Moen faucet and needed a collar removing tool and a cartridge puller in order to remove the cartridge.
Google
May 01, 2017 | Water Water Heaters
Tip
Fix leaking faucets yourself
always rember , anyone having problem with leaking water faucets,for example a bathroom sink faucet is leaking,you don't have to go and buy a new one.save youself some money,buy putting new washers in,and if that don't stop it you will need to change the set that the washer seat agains't.<br /> the way to do this first,you would need a screw driver and take off<br /> off the knobs off the faucets,then you will see the washer you would <br /> replace ,but the water has leaked so long you would need to change the<br /> copper set to do this you need a wrench that you can remove the copper<br /> seat then reassemble the faucet and to make this fix last.<br /> always rember don't tighting the knob just enough to stop the water<br /> from leaking and the washer will last alot longer.doing this yourself<br /> you have saved alot of money.
on Mar 09, 2011 | Plumbing
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    My kohler faucet is leaking. I know how to fix it but the casing is secured to the marble sink. Do I need to remove the cartridge from underneath?
    you generally can work on the faucet from up above. turn the valves off underneath in the cabinet area and remove the knobs or handle . From that point everything should be visible that you need to do.
    Apr 09, 2011 | Kohler Home
    I have a kitchen faucet that is leaking at the base where the faucet connects to the base. It leaks all the time. Do I need to replace the O rings in the stem of the faucet? Or do I need to replace all...
    hi! if tightening the knob(s), (or if you apply pressure on the knob of the faucet,for the models with no thread for open/close), modify the amount of water leaking ,you need to replace the seats in the faucet. if not ,just replacing the o rings should fix your problem.
    Feb 20, 2011 | American Standard Kitchen Faucet 6310 020...
    Delta bathtub faucet
    you need to stick large screw driver up in the faucet and turn it counter clockwise. this might sound ridiculous but it works.
    Mar 26, 2010 | Delta & Single Handle Shower Faucet
    Jan 01, 2010 | American Standard Kitchen Faucet 6310 020...
    I have two leaking bathroom faucets. Hansgrohe 06042. I replaced both faucet valves from Hans part no. 94009000. They BOTH still leak steadily. They worked flawlessly for two years.
    where are they leaking from?
    if they're leaking from underneath, repace the suply lines [between the valve and faucet]. if if from the faucet itself replace your cartrage[s].
    Aug 18, 2009 | Hansgrohe 06042 Tango Widespread Bathroom...
    Water Filter Leaks
    Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
    If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
    If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
    Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
    Nov 18, 2007 | PUR (FM-9500) Air Purifier
    Plumbing Logo
    109 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
