Question about Boating
How do I hook up hoses on a johnson fuel filter
I have a 1985 johnson 90hp outboard ,which I am changing from a VRO fuel pump to a conventional pump which has 3 hose inlets. To which outlets do I hook up ,fuel in, fuel out, & pulse to the new pump? I know which hose is which,but not where it goes on new filter.
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 677 Answers
SOURCE: Size of fuel hose
Mate.If the fuel hoes is no good,cut off about 1inch of hose and take to a hose supply shop.It will be cheaper than buying a 'real' part.Or take the whole thing.Make sure you tell them it's a fuel line to get the correct type of hose.Hope this helps
Posted on Aug 05, 2009
  • 58 Answers
SOURCE: Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Posted on Aug 29, 2009
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
  • 86 Answers
SOURCE: vro pump on a 92 johnson 150hp
If you are having problems with the VRO then I would just remove or disable it and mix your own fuel. It is cheaper and there have been alot of problems with those going out while the engine is running and then they sieze their engine because of the faulty VRO. Mix your fuel 50:1 and you will be able to run all day!
Posted on Oct 16, 2009
I am ready to purchase a boat with a 1990 Johnson 150 hp vro outboard motor. I have read that there may be an oil problem with this model and what the cost may be to correct it. Thanks Al
The following link may help you decide. It is a discussion of Variable Ratio Oiler vs Premix oil and fuel.
There are arguments on both sides that you should read.
https://www.thehulltruth.com/boating-forum/7389-oil-injection-premix-outboard.html
This person likes the VRO, but has a list of maintenance requirements to keep it working well. With a 17 year old engine There are a lot of points of failure that need to be considered. If the VRO fails the engine self destructs.
Keep your VRO.
The Trailer Boats Magazine article in Feb 2000 has lots of good tips to keep your VRO running. Here is a short summary:
Sediment and/or water can build up on the bottom of the oil tank. Draw a sample from the bottom with a turkey baster and squirt it into a jar. If it lookt like you have water and/or dirt, remove and drain the tank. Clean throughly, replace filter and purge/replace the oil line. This sounds like a good thing to do annually.
Replace clear oil cap with black (#176217)
Inspect all oil lines carefully ! If oil lines are more than a few years old (or are smooth vinyl) replace with 1/4" ID rubber (#333485). Avoid tie wraps and worm gear clamps in favor of OEM rachet clamps (#333654).
Inspect all vaccuum lines carefully !! If more than a few years old, replace them.
Inspect all fuel lines carefully !! Clogged filters, anti-siphon valves, kinked lines will cause problems.
Install blue pulse limiter (#435009) to protect VRO from backfires.
Don't run carbs dry as you will suck in too much oil !
There are lots more tips that are model year specific, so go to your local library.
Oct 10, 2017 | Johnson Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Proline boat manual
add the proper amount of oil to your gas then unplug the VrO
Aug 26, 2014 | Boating
Evinrude 120 vro outboard floods easily on startup , could spark plugs be wrong type
No,check vro fuel pump diaphragm.if primer bulb doesn't get hard when priming is a sign of needle and seat not sealing or a hole in fuel pump diaphragm.
Sep 08, 2013 | Sierra International 18-4310 Marine...
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
Vro pump on a 92 johnson 150hp
Sep 30, 2009 | Boating
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Sep 17, 2009 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
21 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
