Question about Sea-Doo US 2008 GTI SE 155
SEA DOO GTI OIL LIGHT STAYS ON
AFTER THE WATERCRAFT IS STARTED AND STAYS RUNNING FOR A MINUTE, THE OIL LIGHT COMES ON AND DOES NOT GO OFF, WE REPLACED THE OIL LIGHT
Rode for 20 min. Engine light & oil light came on. Oil level perfect. Kept running with limited power (5mph) Loud continuous beep. Now runs fine. What should I have service check?
As a PWC puts you out in open water with no way back apart from swimming, I advise having your PWC serviced at the end of every season. You may have had an airlock in the oil line which cleared due to the slow running. Have a general service anyway which on my outboard costs $125.
Sep 22, 2015 | Sea-Doo US 2011 Wake Pro 215
Sea doo won t start
take it back to dealer ss warranty !!
Jul 27, 2014 | Sea-Doo US 2013 RXT -X aS 260
Sea doo troubleshooting
have you checked the intercooler isnt leaking water into the air intake while running ?
Jul 21, 2014 | Sea-Doo US 2004 GTX 4-TEC
Po544 fault code
po544 code is exhaust gas temp sensor functional problem ! is this in the water or on the hose pipe as hose water pressure may be low ? you can only run seadoos for 3min out of water on a hose pipe as the engine cooling system will overheat !
Dec 17, 2013 | Sea-Doo US 2010 GTI 130
Help!! '97 Seadoo GTI, just had the carburetor rebuild, replaced the Rectifier Regulator, replaced the spark plugs and recharged the battery. But the jet ski would only reach 40mph and it would bog down to...
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
Sep 23, 2013 | Sea-Doo US Boating
Key will not make contact so motor can be started.
mite need a key post or the key re coding !
Aug 29, 2013 | Sea-Doo US 2013 GTI 130
High exhaust temperture warnong
You can't run those for for than 30 seconds because your not injecting any water thru the exhaust.
Jul 21, 2013 | Sea-Doo US 2011 GTI SE 130
Seadoo jetski
have you got any fault codes on the screen ? has the intercooler been checked for leaking in to the intake manifold ? press the set button 5 times to see codes if any ! how old is the fuel ? over 5mths then replace !!
Jun 20, 2013 | Boating
Sea-Doo US 2008 GTI SE 155 Logo
47 people viewed this question
Top Sea-Doo US Boating Experts
Richard Lilja
Richard Lilja
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
