Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Frig just not Cold
Our frig has been working just fine. It has always gotten cold. We left for vacation so we turned off the electric. Emptied the frig, and it was off. When we returned, we turned the frig back on, and now it just won't get cold. It's blowing, but the air is blowing cold. I have unplugged it, and tried to start it over, but it simply won't get cold. Can you give me any tips for what I should try to do?
  • 63 Answers
You might have had freon leak out from it sitting unplugged how long were you gone ? plus you need to wait atleast 30 minutes when you unplug your refigerator then plug it back in you cannot keep plugging it on and off it will burn up the compressor / relay overload
Posted on Aug 29, 2007
SOURCE:
I unplugged my bunn for vacation and now it won't come back on I forgot about the vacation switch It has always worked fine before.
If it's plugged into a GFCI outlet, press the RESET button. Do not press the "test" button.
If still no joy, plug something else into that outlet and see if it works. If it doesn't, check that the breaker on your main panel for that circuit isn't tripped. If it is, push it all the way to the off position, then back to the on position. You should hear it click like a light switch.
Jul 19, 2014 | Bunn GRX-B
Returned from vacation and can't get the ice maker to restart. It was working fine before vacation. I emptied the bin and clean it and put the refrigerator on vacation. When I returned the ice maker...
ice maker only works if tempt is cold enough . 15 deg of colder . ck the fans and ck the coil /to see if clean these are very common maintaince problems that cause your problem .. mm
Aug 17, 2010 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
It stopped working, I cant hear any type of compressor and the food is slowly defrosting in the freezer or seems soft but it is outside in the cold garage so I am not positive that it has completely...
The first thing to always check is the electrical receptacle if it is plugged in good check the breakers in your electrical panel to see if you have a tripped breaker. If that proves to not be the issue it might just be a bad thermostat on your frig. Try turning the frig up to its highest setting. Then you will know if the thermostat is working or not. BB
Dec 16, 2009 | Frigidaire FRT21H8 Top Freezer...
Ice in frig air vent
you did just fine defrosting it but, when you put everything back in don't overpack it, leave room for the air to circulate. the heat from the bottom unit will cause enough condensation to leak down the air vent and the it will refreeze blocking your vent again
Jul 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Fridge not cooling
sure is you nailed it, behind the lower crisper drawer is air retunr make sure nothing covering those. removing back panel of freezer will also show problem, id assume iceis building up on either side. remove ive and refrig is restored. make sure doors are sealong sounds like warm aire getting in somehow
Feb 07, 2008 | Amana ABB1927DE Bottom Freezer...
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
171 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
