Question about Xerox WorkCentre 6400X multifunction ( fax copier scanner ) ( colour ) Laser Printer
How do you empty a xerox 106r01368 waste cartridge?
Waste cartridge on the machine is full but my office will not be receiving a new one for at least another week.
5 Suggested Answers
  • 49 Answers
SOURCE: message waste cartridge is empty / not installed at xerox 6100
For this machine I don't think there is a reset, but it is tempormental about the light that shines throught the back of waste cartridge.
Copy and paste this link directly into your address field, and see if you have it inserted correctly and then reboot.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=666,E=0000000000024654785,K=7760,Sxi=13,Solution=obj(20783)
Niallbt
Posted on Mar 31, 2009
SOURCE: Xerox workcentre 265 waste toner full msg
Clean the sensor where the waste toner bottle goes in and just turn the copier off for a couple of minutes then turn it back on. The system needs to reset.
Posted on Oct 20, 2009
MalKontent68
  • 748 Answers
SOURCE: Waste Cartridge Full
The optical sensor looks at a small compartment, that has clear walls; when the waste toner gradually fills the container, it eventually reaches the level above a "wall" between the main container and this small compartment, spills inside and makes not transparent anymore. Some toner might have gotten there and the sensor gives a false full signal. You can get rid of it by cleaning this compartment with compressed air.
Obviously, the sensor might be plain broken as well, but the above is perfectly true - it saves the day when the printer stops and we don't have a new waste container... I pour out the toner and clean the inside thoroughly with compressed air, especially that small look-through compartment.
Posted on Oct 24, 2009
wrinaldo
  • 185 Answers
SOURCE: Xerox c2424 has error message
The Waste Tray Optical Sensor 119-6487-80 is probably bad, which contributed to the overflowing ink. Look at the diagram #6
Whit
Posted on Oct 22, 2010
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
Can i empty the 7120 waste toner bottle?
No you should not empty this bottle. It is designed to keep the excess toner inside itself and should be disposed of properly. NOTE: To return the used Waste Toner Container for recycling, follow the instructions included with the new container. If the instructions or shipping label are not available, click on the [Recycling] link under the Product Resources section of this window for additional information. Follow this link for detailed instructions on how to replace the bottle once you have a new one onsite. http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=161,E=0000000002703235792,K=5302,Sxi=14,Case=obj(1554) Hope it helps!
Feb 10, 2011 | Xerox Office Equipment & Supplies
How do i empty the waste cartridge on my xerox phaser 7500?
Xerox has designed this so you must buy a new one from them. It's got a digital chip inside the waste cartridge, if you dump out the waste, the printer knows its getting the same old one put back in even if its empty. Wasteful printer. I hate it.
Aug 24, 2010 | Office Equipment & Supplies
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Phaser 7300N - Where is the waste toner container?
That machine does not have a waste toner container like the xerox phaser 7400. What it does is all the waste toner is cleaned at the IBT belt. If you remove your IBT belt part number 016-2000-00 you will see there is a plastic container at the end and that is where the wast toner is.
Oct 13, 2009 | Xerox Phaser 7300DN Laser Printer
Message waste cartridge is empty / not installed at xerox 6100
Niallbt
Mar 31, 2009 | Xerox Phaser 6100/DN Laser Printer
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Xerox WorkCentre 6400X  multifunction ( fax  copier   scanner ) ( colour ) Laser Printer Logo
145 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
