Polaroid kdt1c c4
The remote will not work. Cant cut the tv on either using the power button
2 Suggested Answers
SOURCE: My Polaroid KDT1C-C4 became locked accidentally, can't unlock it.
You must press and hold the F key and press mute
Posted on Feb 10, 2010
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Aug 21, 2012 | Polaroid TLX-01511C LCD TV
My tv is set on zoom3 and i dont have my remote control,; what can i do? I've bought universal remotes but no luck!
Doesn't appear to be a good way to do this without the remote, you can try to do a factory reset,
Factory Mode Procedure
1.Power on TV.
2.Press volume up and channel up buttons on the TV simultaneously and release.
3.Power off TV with remote or power button to exit.
If this doesn't work you can get a polaroid replacement remote here:
http://www.discount-merchant.com/Polaroid-RC-201-Remote-Control-p/remote-9039.htm
Apr 01, 2011 | Polaroid FLM-323B Television
The tv was turned off with the remote 'set' button. Now, none of the power buttons including the one on the tv itself work to turn the tv on. Perplexed.
my remote control will not work after changing the battery on POLAROID ORIGINAL LCD FLU-2632 TV REMOTE CONTROL please help
Dec 12, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid tda-03211c hdtv.i hooked up to use as
Since the tv is not turning on try unplugging it from the wall outlet for a few minutes. Up to 10 or 15 and see if the set will reset on it's own. If that does not work press the power button and when the front light comes on press and hold power button for about 10 seconds to see if it will reset this way. Maybe this work.
Mar 04, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Cannot open poloroid kdt1c-c4 remote (to change batteries etc)
the back of the remote entire half is going to slide down if you apply pressure to it and push downward.. no screws to take out no cliping system visible. just press in and down .
Nov 27, 2009 | Televison & Video
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Sep 09, 2007 | Televison & Video
Remote control problem
Have you tried "One for All" universal remotes?
Jun 10, 2007 | Polaroid 1720-7 Remote Control
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
