Question about Cell Phones
Philips SHB 4000 bluetooth headset won't charge
I plug in the charger and it says its not charging, the first couple days i had them they did but now the are dead and wont charge
5 Suggested Answers
  • 10 Answers
SOURCE: 'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Posted on Apr 06, 2008
SOURCE: cect i9 wont charge battery is fine
The I9 battery charger is th problem. There is a small tab on the bottom edge of the batery that allow it to clip in the phone. This tab prevents the battery from going all the way into the charger which causes a missalignment with the contacts and due to the contacts being very thin they tend to break off. If this happens you must use the USB cable to charge the phone, it plugs in under the charger. If your contacts are good you can take a thin knife and ease the tab over the edge of the plastic lip on the charger alowing the battery to seat correctly in the charger making the proper connection.
Posted on Feb 25, 2009
SOURCE: LG shine wont charge
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Posted on Mar 05, 2009
vortash
  • 431 Answers
SOURCE: Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
Posted on May 13, 2009
Jabra extreme2 will not charge
All things can go defect. But to find out if it is your charger, cable connector or the battery you have to look very close. Perhaps you even try another charger and or try to charge an other headset.
When you are using this one for a couple of years now, day by day, perhaps it is time to start saving for a new one?
Jul 21, 2014 | Jabra Extreme2 Bluetooth Headset
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
I am having problems getting my Voyager Pro bluetooth to recharge. I am not getting the solid red light to indicate the unit is charging.
So if it won't charge, it may be that the charger is bad, and you may not have a way of charging it to find out if it is the charger or the battery. If it is the charger you can get a new one, there is a link below to the right part. If it is the headset and it is still under warranty return it to the vendor.
Plantronics 79414-01 AC Adapter
Good luck from Headsets Direct!
Oct 21, 2010 | Plantronics Voyager PRO Bluetooth Headset
Lost charger who can I call?
The nice thing about the ps3 is it can charge the bluetooth from the charge cord for the controllers. Just plug the bluetooth into the charging wire from the ps3 and the bluetooth will charge.
Jan 27, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Aug 22, 2008 | Jabra JX10 Bluetooth Headset Headset
Bluetooth not charging
The internal battery is bad or your charger is faulty, got a kink in the cord.
Jan 22, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H350 will not charge
There is two way you can do 1) ensure that the charger have output ( use volt meter to check or use handphone to confirm ).2) ensure the bluetooth charge contact is clear for charging ( or use contact cleaner to clear ).if you have done this two and still no charge then the battery in the bluetooth may be dead. hope it help.
Aug 20, 2007 | Motorola Mobility H350 Wireless Headset
Cell Phones Logo
649 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
