Question about Vacuums
Beldray steam cleaner instructions
When we switch on red light comes on then it should go blue but keep flashing red and not heating we have only had it about 5 weeks got it from 24studio please asvise
SOURCE: Polti Vaporetto
Dear Terena
Had the same problem with a polti vaporetto 1500 ( vtt 1500 ) after butchering the big valve on the top I realised that the problem was that there was a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so I got a piece of wire ( brake cable form a bike shop ) long enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone ( try pushing it down hard as you turn it Whilst it is warm only not hot ) then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future I have only just reallised this so dont feel alone.
Pete
Posted on Dec 04, 2007
reddevil6
  • 1673 Answers
SOURCE: have an old Hoover steam
Check the filters, make sure they aren't clogged. Also if this has the foam filter on the inside of the tank lid, make sure it has at least a 1/4 is gap from the top.
Posted on May 26, 2008
SOURCE: Euro-pro shark steam cleanercs618hd
I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
Any ideas?
Posted on Oct 10, 2008
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
SOURCE: No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Posted on Oct 29, 2008
I have got beldray. Steam mop not a vauuum I put water in switch it on red lights come on then go blue I will turn on steam and it will just not steam.
Lord Blake there sounds like there is a problem with the trigger or the seals for the steam pipe. Check it over completely and make sure it's assembled right.
Nov 02, 2014 | Vacuums
What to do when blue light is on and water wont come out the steam penguin
Blue light comes on top of penguin gets hot but the water tank stays cold no steam
Oct 28, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
Require instructions/manual for Beldray 2 in one steam mop
I WAS AFTER THE WEB SITE FOR BELDRAY AS I NEED MOP CLOTHS BUT CAN NOT FIND THEM SOLD ANYWHERE . I COULD NOT EVEN GET THE 2 IN ONE TO WORK BUT FINALLY DID BY REMOUVING THE PIPE WITHIN THE WATER BOTTLE WITH THE BALL VALVE ON THE END AND THEN IT WORKS A TREAT WHEN USED AS A FLOOR MOP AT LEAST . I MAY HAVE TO REFIT THE PIPE AND BALL VALVE WHEN I NEED TO USE IT AS A HAND DEVICE I HAVE THE MANUAL THAT CAME WITH THE 2 IN ONE BUT THAT'S NOT A TECHNICAL MANUAL IF THAT IS ANY HELP
Apr 10, 2012 | Vacuums
Due to illness etc I've not used my Polti 2400 for a couple of years. Now I want to use it I have all the paperwork that came with it - except the instructions! Can you help.
Polto steam cleaner 2100/2400 yellow, the on switch will not click on so the water does not heat up. The orange light comes on when i press the on switch but goes off and the button comes back up as soon as i let go. Any ideas will be gratefully received.
Dave
Mar 14, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
I have a bissel pro heat carpet cleaner that doesn't spray cleaner solution, everything else works, but I don't know whether it's the pump or the heat unit.I'm assuming that the pump unit must be bad since...
If you still have spray through the attachments then its the heating element. If not and your sure the belts are good ( if there intact but are a year or more old they need to be replaced ) then its probably the pump
Jun 27, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Shark euro pro steam cleaner model s3325
Call them at 1-800-798-7398
Have the model number, the country it was made in and the date it was made. All found on sticker on bottom of unit. They are foreigners that answer the phone, so be prepared to spell everything. It takes 3 weeks to get the parts but I found them to be inexpensive.
Sep 06, 2008 | Euro-Pro Ultra Steam SharkTM II Hard...
McCulloch Steam Cleaner Problem
does your motor run if not there is a service switch to the motor inside the unit that has to be adjusted
May 16, 2008 | McCulloch MC1275 Steam Vacuum
Vacuums Logo
585 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
