Question about Lexmark C544dn Laser Printer
Search Fixya...lexmark c544dn
Language issues by mistake changed language
I have a Lexmark C544dn printer. I am getting a yellow haze on the right side of all pages printed.
Check the transfer belt and clean if necessary with Isopropanol (IPA), and a soft clean cloth. Also check the drum for the same. Handle with extreme care as these are fragile and expensive. If none of those fix the issue you may need to get the laser lenses cleaned professionally.
Sep 09, 2013 | Lexmark C544dn Laser Printer
Our lexmark c544dn has a paper jam but when I open the front cover I do not see one. What else should I do?
Pull back the fuser cover ( black upper area) and look for the jam beneath the black roller with paper sticking up - to pull it out
Aug 05, 2011 | Lexmark C544dn Laser Printer
109.05 service printhead error
Please click on the link provided below.
http://bitly.com/nIjA4L
If this does not resolve the issue, please try to reseat the printhead cable.
Turn the printer off, and remove the rear. Check the cable at JMIRR1 for shield. proper connection to the controller board, the printhead cable for pinch points, and the cable
or connector for any other damage.
For further assistance, please contact Lexmark Technical Support Center.
Jun 16, 2011 | Lexmark C544dn Laser Printer
106.08 service printhead error lexmark C543DN
Jun 15, 2011 | Lexmark C544dn Laser Printer
Change control panel of lexmark X3350 printer from Chinese to English
Hello. In order to change the language for your Lexmark X3350 printer you should follow these easy steps:
First of all, power off the printer and then hold the + and power buttons (at the same time) for 5 seconds.
This action will reset your language settings. You will now see an English prompt. If it's not there, search it by pressing the + button to navigate and press the arrow button to select it.
I hope I helped!
If you have any other questions, please leave a reply!
Thank you for using FixYa!
May 26, 2011 | Office Equipment & Supplies
Lexmark printer c544dn. The printer is saying to "82 Replace waste toner box"
Please click on the link http://bit.ly/psOcDA to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
May 10, 2011 | Lexmark C544dn Laser Printer
How to change the language on my lexmark x73 printer
Thank you for choosing FixYa! Kindly follow the steps below to resolve the issue that you have.
tech4allmen.jpg I hope it helped you. If it did I would greatly appreciate it if you click on YES to vote for me. Thank you for choosing FixYa!
Mar 06, 2011 | Lexmark C533DN InkJet Printer
Lexmark C544 error code 82 replace waste toner box will not clear after last firmware update
Try to reseat the waste toner box and power down the printer for at least 30 seconds.
If you need further assistance, please contact Lexmark Technical Support Center
Jan 14, 2011 | Lexmark C544dn Laser Printer
Error code 900 Lexmark c544dn network printer
900 errors usually point to fuser or fuser related component failure.
Please have the printer serviced.
Oct 06, 2010 | Lexmark C544dn Laser Printer
I installed my Lexmark 4800 series and when it asked for the language, I pressed OK when it was a language that I just dont understand with a bunch of V and K. I wanted the french instruction, can someone...
Go to the Lexmark Support page. Enter your model number in the Search by Model box and click it when it appears. That will take you to the support page for your printer.
Type "language" inside the "Search the KnowledgeBase". Click "Search". One of the top choices should be about changing your language. Click it and follow the instructions.
If you need additional help just comment back.
Nov 04, 2008 | Lexmark Office Equipment & Supplies
Lexmark C544dn Laser Printer Logo
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
