Question about Refrigerators
Tfx22cr my frigerator is not getting cold so what can i do to fix it
  • Refrigerators Master
  • 8,220 Answers
Most times the defrost system has something go wrong. Wether electronic or mechanical timer refrigerator have the same other 2 components which is a derost heater to keep frost off the evaporator and a defrost heater thermostat to cease power to the heater when the temp gets warm enough to melt the frost. It is just that simple. After cleaning the coils below and behind an ice box, I look for signs of frost on the back wall of the freezer. If I see it I know their is ice in the evaporation compartment. One thing you can do if you do not wish to take it any further or cannot pay for service is simply unplug the ice box and let it thaw out a few days. By unplugging it and allowing it to thaw out the ice box will magically work fine again for several weeks till the ice clogs the evaporator again. If you wish to fix the ice box remove the service panel and look for the termination thermostat is what I do. If it appears swollen it has failed and therefore the heater will not come on and defrost. Also the heater itself might be bad especially if it is a glass one. Note: The bimetal defrost thermostat will only check good if it is below 50f. It opens above 50f that is its job. It closes at 25f and llows for power to get to the heater. That is how they ALL work. No rocket science needed. On the newer models with computer controlled defrost if the termination thermostat is ok and the heater is ok and the unit has mechanical thermostats to control the cooling I recommend just replacing the defrost control electronic box, if it is a fancier one that has a brain to determine cooling then I recommend replacing thermisters first or at least checking them. You can get a service manual on my googledrive page. Appliancejunkgoogle drive. Google it. LOL
Posted on Jul 17, 2013
My Freezer leaks into fridge, what can I do?
now if the refrigerator is leaking cold air from the freezer, that is normal, there should be a vent, or control handle near or inside the frigerator on the freezer side of the refigerator, you can open or close so you control how cold you want your food to be cold
Apr 22, 2015 | Refrigerators
The frigerator isnt working but freezer is how can i fix it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Refrigerators
Friger too cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Sep 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freon filled the kitchen. Freezer stopped freezing frigerator not cold anymore, can the refrigerator be repaired or is it gone?
Almost anything can be repaired...just depends how much you want to pay to get it fixed. The cost will depend on the location of the leak. If it just a bad braze you can problem get it repair for $250 to $450.00
If the evaporator coil/plate is bad it will most likely be cheaper to get a new unit unless parts are still under warranty.
Jan 09, 2010 | Refrigerators
Frigerator not cooling
I dont know how often you cleen the coils pull the grate off the front and panel off the back if the cools are all dusty it will stop the fridge from getting cold take a vacuume or air compressor and get it all clean it should work then
Dec 12, 2009 | Refrigerators
Kenmore Top Freezer not getting cold (freezer or refrigerator), fan works. Occasional click down by compressor? Any advice appreciated. Trying to fix cheap as this is an 8 year old 2nd frigerator we keep...
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
The frigerator and freezer are not getting cold enough.
It sounds as if your unit is low on freon.You will need to have a quailfied repair person to refill.
Jul 02, 2009 | Refrigerators
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Frigerator is freezing.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Freezer not cold enough warm on the frigerator area
Replace the defrost heaters and or the bi-metal. Also make sure that all the ice is off the evap coil.
Jun 29, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
