Question about Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37SV no blue light
My Sceptre X37SV simply quit, no blue light. The PS fuse is good, and I have 120 VAC at the PS. The two caps next to the power connector appear to have done some arcing, but they act like caps to the meter. I could probably figure this out if I had a print of the power supply, but I'm kinda shooting in the dark...
  • christibajia Dec 04, 2008
    have the same jproblem and i'm not electronically inclined, how much would i expect to spend if i bring may tv to a shop?
I don't think those are capacitors. They are varistors and (as a pair) they are in series between the mains and the load. Current flows through them so if they have dry-jointed then you have an open circuit and no current flow. This seems to be a recurrent problem. I'm trying to locate a replacement but I can't find the characteristics of the SCK 085 listed anywhere.
My guess is that this is a US problem only. In other countries with higher mains voltage, the power supply draws a lower current and doesn't cause the varistors to overheat.
Posted on May 19, 2008
SOURCE:
Blue light blinks will not turn on
chances are a capacitor is blown on your psb.have a look for buldging caps,its a plauge for these tvs.replace with like kind,very cheap to buy from maplins and the like,will require soldering and basic skills
Mar 19, 2013 | Sceptre Komodo X37SV 37 in. LCD Television
Blue power light flashs and won't turn off and has no picture or sound
It may have bad solder joints in the power supply board, look at the solder joints on the Thernistor and DC filter caps for leaky/domed tops.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 25, 2011 | Sceptre X37sv-Naga 37 in. LCD Television
Light comes on like itnhas power , but no display
Blue light keeps flashing as though it is on but no picture or sound and it does not turn off
May 13, 2011 | Sceptre X37sv-Naga 37 in. LCD Television
Unpluged 37in sceptre tv and 15 min later pluged back in red on off lite no lit tv expert said leave un pluged 4o min then try did no responce is there a fuse? anyway no tv
Yes there are fuses, but if you have led lighting up then it's not the main fuse, Why was tv unplugged in the first place, did you have problems before with set? It sound like power supply is bad, and it would be cheaper to just replace, you can check with discount-merchants.com, or shopjimmy.com or even vancebaldwin.com
Dec 15, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
The blue power light just binks when it's plugged in, the power button doesn't even have to be pressed. is that the power supply or the logic board? (already ruled out inverter board)
Check the power supply board for those dead capacitors.It alway have bulges up on it tops or puff up on it tops.Replaced those dead gases leakages capacitors.Than,it is the power supply board it dead power supply board.No,capacitors bulges up on it tops or puff up on it tops.The logic Tuner board is dead.
Jul 15, 2010 | Sceptre Komodo X37SV 37 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga 37 HDMI port is not making contact
hd EZ lock by Blue Echo Solutions is a Universal HDMI Locking Adapter, the only one on the market. It works with most HDMI Cables and components and attaches to your component's chassis, using the existing screw above or below your HDMI Input or with the supplied adhesive. It supports your HDMI Cable from the component's chassis, eliminating stress on your HDMI Input and keeping your HDMI Cable in place. www.blueechosolutions.com
Oct 17, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Scepter X37sv-Naga LCD
The Sceptre TV do use the Sony codes. However, the cheap universal remotes do not have the buttons needed. The Volume Up/down and channel up/down are controlled with the circle of buttons (arrows) in the middle of the remote.
You can get an OEM remote from Sceptre. They still have them available. Sceptre is in California.
Jan 04, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
New Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Aug 28, 2006 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga 37 in. LCD Television Logo
269 people viewed this question
Top Sceptre Televison & Video Experts
leeboy3909
Level 1 Expert
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
