Question about Intel N440BX Server Motherboard
Beep bios 4-3-4-3 short beeps-what could it mean? no bios while setup,black screen,no hdd,no mice,no pad only memory thanks stanislav
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Http://www.techrepublic.com/article/step-by-step-deciphering-bios-beep-codes/#.
Posted on May 21, 2014
sandrew
  • 2961 Answers
SOURCE: No screen display at all and no short beep for post-intel D845WN board
Try the old memory back in and see if you get the bios screen showing up, if not find the clear cmos jumper either marked JBat 1, clrclk, clrcmos or similar and try again. If neither your old memory or new no longer allows the pc to boot, i would say that the motherboard has been stressed when you have fitted the memory by forcing a flexing in the board and damaging the cmos chip, only replacing the board can resolve the issue if that is the case
Posted on Jul 03, 2007
SOURCE: intel d945gnt
Yesterday night i resove the problem with the intel by many e-mail.
For all guys that have the same problem , the solution is:
1- put the jumper in position pin 2 and 3.
2- turn on the PC with jumper in the same position ( pin 2 and 3)
3- the bios start in "recovery mode"
4- deselect the memory "aggressive mode"
5- save bios setting, then power off the PC
6- set bios jumper in position 1 and 2
coolhandan thx for attention and please insert this solution in intel D945GNT archive for future customers that fall in same problem. Sorry for my bad English ;) THX at all
Posted on Nov 18, 2008
jell587
  • 447 Answers
SOURCE: My Intel D102GGC and Mercury 915GLV motherboard not wake up
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
Posted on Mar 06, 2009
dlundmark
  • 797 Answers
SOURCE: Intel DG45ID motherboard bricked
Here you maybe should not set the manual setting to 800 mghz.
Use the default setting as you can save and reboot it.
There may be a problem with the way the bios sees the memory. Also examine your manual carefully for indications of how the memory needs to be installed.
Some boards require two or more modules to be installed, and will not run correctly with out the modules required installed. Some of these boards will not allow mixing anything except exact sets. That is to say each module must be the same. Some boards are far more tolerant of kinds and makes of modules.
With out the memory, you will not have anything to run on.
So, I would suggest to let the bios set what it sees.
http://www.google.com/search?hl=en&q=Intel+DG45ID+pdf&btnG=Search&aq=f&oq=&aqi=
"Four 240-pin Double Data Rate 2 (DDR2) SDRAM Dual Inline Memory Module
(DIMM) connectors with gold-plated contacts
• Support for:
. Non-ECC, 1.8 V, DDR2 800/667 MHz memory
. Serial Presence Detect (SPD) memory only
. Unbuffered, non-registered single- or double-sided DIMMs (except double-sided
DIMMs with x16 organization)
. Memory configurations listed below:
• Up to 2.0 GB utilizing 256 Mb technology
• Up to 4.0 GB utilizing 512 Mb or 1 Gb technology
• Up to 8.0 GB utilizing 1 Gb technology
• A minimum of 512 MB of total memory is required"
"NOTE
To be fully compliant with all applicable Intel ® SDRAM memory specifications, the
board should be populated with DIMMs that support the Serial Presence Detect (SPD)
data structure. If your memory modules do not support SPD, you will see a
notification to this effect on the screen at power up. The BIOS will attempt to
configure the memory controller for normal operation."
So, the memory is dependent on the configuration. It appears that this board requires 4 modules at once to be installed, depends on the amount of memory per module as well.
Be careful about flashing the bios. By doing that you can ruin the bios and make the computer completely unusable until you get and install a new bios module, if you do not pick the exact correct flash version.
Posted on Aug 30, 2009
  • 4 Answers
SOURCE: my motherboard gives 8 beeps and shows no video,
Continious beep codes are caused by the memory (RAM). Try reseating your RAM just plug it out clean it then put it back in. Or try the other memory slots. Just transfer your memory to the other slot if you have an available slot on your motherboard. Or simply buy a new memory (RAM). Just make sure it is compatible to your motherboard. Beep codes means the computer is not reading the memory (RAM) properly. There is no post and no video in your computer because the RAM is not working properly.
Posted on Jan 13, 2011
Intel server MB
Find out which BIOS is installed (websearch on server model) then search for Bios Beep Codes for that BIOS. Check what 4-3 4-3 means, you may find it is something simple. If you can get floppy working you may be able to flash BIOS but again you need to know which one
Jul 17, 2013 | Intel n440bx - Server Dual Slot1...
Tip
Beep Codes (Different BIOS) " What they mean "
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
Phoenix bios release
stanislav, how many HDD do got 2 or moore.
what did you in BIOS.
did you set optimal defaults.if so BIOS can have changed your bootdrive.WINDOWS is on one of the drives.you have to change back.
Jun 08, 2013 | Intel Server Board N440BX Motherboard
Powers on for 5-6seconds then beeps one time and shuts down
Here are the beep codes for common BIOS programs:
1 BeepA single beep from an AMI based BIOS means there has been a memory refresh timer error. The solution is often to replace the RAM in the computer.
A long beep from AWARD is probably memory error.
1 short beep from AWARD bios & PhoenixBIOS and most others is a positive ok signal.
Without more information, it sounds like it is a memory problem. Remove the memory and see if it will boot to the BIOS/setup screen. If so and you have multiple memory sticks, put one in and try to boot. If that fails try the other.
Aug 20, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Gateway c140 beeps
If you have an AMI bios (you can tell when you boot and the black screen has writing on it at startup - the bios type and version is the first thing at the top of the screen)
1 long and 3 short beeps indicates that the memory is not seated properly. You should check that it is secure on your motherboard. If it is seated securely, your memory is maybe faulty.
Mar 21, 2008 | Computers & Internet
Dell webpc,,2 short beeps and keyboard error
i can help you with the Post-Code Beeps.
AMI Bios= 2 Beeps. Parity error In First 64k Ram. ( reseat Memory ) Post Failure 1 or more Of the Hardware test Have Failed.
IBM Bios= 2 short Beeps. Post Error ( Memory Possibility ) review screen for details.
AWARD Bios Codes = 2 Short Beeps. Any Non-Fatal Error. Enter CMOS setup to reset.
I,d go for Memory ( RAM ) But first enter bios setup Usually F2 Or Delete escape et,c. Reset to defaults, and see if that solves your Problem.
Mike @ Compurepair.
Mar 07, 2008 | Computers & Internet
Intel N440BX Server Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
