Question about Camping, Backpacking & Hiking
Disadvantage of woter mining resouces in SA - Camping, Backpacking & Hiking
Panasonic f61 output
If what you identify as the output IC has failed, one or more speakers would be affected.
Nov 23, 2013 | Panasonic sa-ht930 Home Theater Audio...
Tip
Disadvantages of exercise bands
Exercise bands are a cheap and convenient piece of exercise equipment that are mainly used in rehabilitation. Here I will talk about the three major disadvantages of exercise bands. First of all, if you're looking to get bigger and stronger, exercise bands are not for you. The amount of resistance that exercise bands provide is not enough to cause hypertrophy or any serious strength gains. Dumbbells, barbells, and machines are a much better choice if you're really serious about the gym. Secondly, it's hard to know how much resistance you are using with the exercise band. This makes it difficult to keep a progression chart because you don't know exactly how much resistance you used last time. Third disadvantage is that low quality exercise bands can be dangerous. For example, if you do a certain exercise and all of a sudden the band snaps, you can strain a muscle. Also, if the band flies and hits your eye/skin, it can cause an injury as well. In conclusion, if you're look for a safe rehabilitation program or light exercise, then exercise bands are great for you. But if you want to make strength and gains, drop the bands, go the gym, and pick up some dumbbells.
on Aug 20, 2012 | Exercise & Fitness
Here in Johannesburg South Africa I need a simple easy to use handheld GPS. The best buy seems to be Garmin Nuvi 1300. But now I see it has been discontinued. Is there any disadvantage in buying it or do I...
There should be no disadvantage to buying a discontinued garmin nuvi 1300 as garmin continue to support their discontinued models. Even if you buy a new one now it will be probably discontinued next year since garmin seem to create a whole new series each year or so. Most of the garmin satnavs in use are discontinued models. When I bought mine the 1300 hadn't even been released and I have had no problems.
May 30, 2011 | Garmin GPS
How do you download or where do you go to download the dell resouce cd
Hello
Thank you for using FixYa for your problem
The easiest way would be to ring Dell on there support line and let them know of your model number and ask them where the resouce download will be
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 22, 2009 | Microsoft Windows XP Professional With...
Top paper feed does not feed 1 at a time, feeds multiple sheets or envelopes
Check for obstacles - top trays got biggest disadvantage: u may easily drop something into it. I`ve found 1GB memory card in mine
Dec 11, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Where can i get a user manual i've mislaid mine
This one looks close.
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Receivers/model.SA-XR10
Nov 28, 2009 | Panasonic SA-XR15 Receiver
*** sa recuperez pozele sterse de pe aparat?
descarca un program free de aici: http://www.snapfiles.com/screenshots/mjmphotorecovery.htm
iti va recupera pozele. bafta. mai multe detalii pe id mess : naebarbat
Oct 17, 2008 | Fuji FinePix A400 Digital Camera
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
No, its my Technics SA-GX550 amplifier - have a problem - HELP!!
Im having the same problem with mine. The problem seems to have started after I placed a vcr on top of the unit. I am thinking that It may be getting too hot. But don't really know.
May 05, 2008 | Technics SA-DX750 Receiver
Camping, Backpacking & Hiking Logo
71 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
