Question about Dishwashers
Meiko error 901
I keep getting a 901 error code on my meiko dishwasher. any ideas on what this means?
Kitcheneer
  • 11 Answers
SOURCE: Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Posted on Feb 05, 2007
Kitcheneer
  • 11 Answers
SOURCE: Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Posted on May 10, 2008
Kitcheneer
  • 11 Answers
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
  • 7 Answers
SOURCE: Err Code 210
What you need to do is check the resistance of the booster tank temperature probe. The error 210 means a short circuit in the booster temp probe. At room temperature, the resistence should read about 1k Ohms. If you are reading significantly lower than that, then you will need to replace your booster temperature sensor. You also want to check the 4 pin square molex connector on the I/O board on top. Make sure all connections are tight, secure, and that there are no "bridges" across the connections for the temp sensors.
Posted on Feb 20, 2009
whytfang
  • 170 Answers
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
Posted on May 13, 2009
Dear sir please explain me about mieko dishwasher machine DV 125.2 Error 901 what is the issue
Try contacting the manufacturer directly- according to the operating instruction manual for your unit: MEIKO Maschinenbau GmbH & Co. KG, Englerstr. 3, D-77652 Offenburg, Tel.: +49/781/203-0, Fax: +49/781/203-1121
Feb 13, 2017 | Dishwashers
Po 121 code
Error 121 with Meiko dishwasher means
Door not closed Check connection S1
Change microswitch
Check microswitch adjustment
Replacing a defective I/O circuit board
Apr 18, 2014 | Meiko Dishwashers
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
Meiko dv80.2 message: info 124 we don't know what
you have opned the hood close the hood the error will disapear
Jun 13, 2011 | Meiko DV 80.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
it's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Jun 24, 2009 | Meiko FV 40.2 Dishwasher
My meiko Dv 80 dish machine keeps showing and info code of 420. What does it mean and what should I do?
info 420 means shortage of rinse agent reported "ready for washing"state. you may have an empty or low rinse in your bottle , also could be filter on your dosing tube slightly bloked , or your doing pipe may be bloked . if not them your pump might be fauty
Apr 03, 2009 | Meiko DV 80.2 Dishwasher
Err Code 210
Feb 19, 2009 | Meiko FV 40.2 Dishwasher
212
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Aug 31, 2006 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
294 people viewed this question
Top Dishwashers Experts
Owen Barnes
