Display panel does not work
SOURCE: problem with my webcamera
Normal
0
See section C. Windows Live
Messenger in the info below to setup the Audio & Video.
Also send this to your family
and friends so they have their computer setup properly.
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html
) set it up as follows:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
NOTE: Your audio and
video should work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: sony midi Hifi switching itself off
These digital amps are very prone to blow if the speaker wires are shorted so Sony appear to have put in a protection system that mutes the amp when this happens. You have to unplug the amp for a minute till the light goes off, make sure no speaker wires are touching each other and then it should work ok. I found the same problem with one I bought 2nd hand.
SOURCE: sony hcd-va550. when switched to
sony hcd-va550. when switched to cd the display reads initial.
SOURCE: hi i have a sony
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
SOURCE: HI Have a Sony HCD H51 CD spin motor not turning
check the ic and the transistor that the motor feeds from they might be bad.good luck.
