Question about Gateway GT4016 (6528) PC Desktop
Startup When the machine has been shut down for any length of time, it will not start back up. Gateway tech had me remove the cpu and re-seat it, and it started. But this happens everytime it is shut down. Sent it back to gateway, they "fixed" it and sent it back. Same problem, only now it only starts after I reseat the cpu 5 or 6 times. Once it starts, no problems. Called gateway, it's now out of warranty.
  • 59 Answers
Sounds like a new power supply needed...could be motherboard, but a power supply is $29 and a new motherboard could be up to $250 from GW. Good luck.
Posted on Aug 28, 2007
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
GT4016 hit pwr button comes on flashes three
Check the USB ports for damaged contacts. If the supply powers up and then shuts down immediately, you have a critical error. Damaged USB port contacts can cause this but so can graphics cards etc. Open the machine up and remove all cards and memory sticks and unplug all the drives but LEAVE THE CPU ALONE!! Now, turn it on. If it boots and starts beeping ( which it will with no memory installed) shut it down and reinstall each item you removed one at a time and turn it on after each single thing. When it stops booting and does whats its doing now then the last thing you plugged back in is the issue.
If it still doesn't power up with everything removed then the issue is in the mainboard. If this is th case, my advice is to seek professional advice..
Dec 02, 2009 | Gateway GT4016 Desktop PC
Have gateway pc with vista. For no apparent
Possible problems:
CPU over heats / causes shut down.
Virus / Malware.
Defective heat sink/fan
defective CPU.
Improperly seated CPU.
Nov 24, 2009 | Microsoft Windows Vista Home Premium with...
Gateway 702GE desktop When i push the front botton to start it up,the fans start to turn and then stops with no operation. The small green led on the motherboard stays lit and green and the front start...
try removing all the cards from the expansion slots and remove the ram sticks. disconnect the drive cables from the board but dont touch the cpu or power connectors. Now hit the button. If nothing changes, probable board fault. If it now boots up and starts beeping ( which it will when no ram sticks installed) shut it down and reinstall each drive connector, ram stick and card one at a time booting between each item. when the faulty item is connected, the board will stop booting and you can replace that item. Many things can also cause this. Bad connections to ram sticks and video cards, damaged usb port connections, failed cpu's, failed psu's etc.. You may still have to take the machine to a professional repairer to have the problem diagnosed.
Nov 02, 2009 | Gateway 702GE PC Desktop
I get 3 beeps and no video on my gateway desktop
The beeps usually meen that the memory is either incorrect or not inserted correctly. Try removing the new memory and go back to the original configuration. Though not recommended, putting the memory in while still plugged up should not be the problem.
Sep 01, 2009 | Computers & Internet
Gateway GT5228 Will NOT Startup
Jul 04, 2009 | Gateway GT5228 (7156) PC Desktop
It's possible that there is a thermal problem that's causing the CPU to shut down to avoid damage. Make sure the CPU fan is running on startup, and that the heatsink is properly seated and secured.
If it's not a thermal problem, there are any number of other possibilities, starting with an operating system (software) fault. More information would be necessary to continue diagnosis.
Jun 26, 2009 | Abit SG-95 Motherboard
Turns on, then shuts down before anything shows on monitor
I am an IT Tech of 11 years, I have found this problem and have solved this problem on the Gateway machines. Also works on the Gigabyte, ECS and Biostar motherboards in the same machine/s. It is not the memory, video, hard drive, or processor so rest assured. This is relatively an easy fix for those that are tech friendly. Remove the retarded one plug front panel power plug, remove the pins for the reset button and that does it. How you fix it from this point is up to you totally, but that does fix the problem. It is a common and frequent problem that mass producers have when developing wiring for them.
Oct 11, 2006 | Gateway 310S (2900621) PC Desktop
Gateway GT4016 (6528) PC Desktop Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
