Question about Cameras
Traveler dc5600 What is the capacity of the maximum external SD card
  • 641 Answers
SOURCE: SD Card capacity and make problem with IXUS40/SD300
Basally, you are not limited with the SD card capacity. It is an "economic" decision only. Sandisk is one of the best companies for it.
Posted on Aug 07, 2007
  • 3 Answers
SOURCE: Coolpix 5200 + 4GB SD card
Any size SD card will work. The capacity limit is with the card, not the camera. All the camera does is serve as a recorder/reader for the card.
Posted on May 13, 2008
  • 374 Answers
SOURCE: Casio Exilim EX-Z55 - SD card compatibility
A 1 GB card is the highest that you can go with this camera.
Posted on Jul 14, 2008
SOURCE: Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
Posted on Aug 13, 2008
SOURCE: What is the maximum capacity for a SD memory card
1 GB - not sure if there is a firmware upgrade available.
Posted on Jul 11, 2010
Binatone Homesurf 744 - put in micro SD card but nothing will save to it although it says it is there (can unmount it).
Please make sure the capacity of your microSD card is not larger than the maximum card capacity allowed by your device. For example, if the maximum card capacity allowed by your device is 16 GB and your card capacity is 32 GB, your device may not recognize it. And is the "unmount SD card" option grayed out or solid ?
Hope this helps.
Dec 16, 2014 | Cell Phones
Settings stopped
Maybe the capacity of your SD card is greater than the maximum capacity the tablet can handle. For example, you inserted a 64 GB card and the maximum capacity allowed is 32 GB. Check the tablet specs.
Nov 26, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
What is the maximum gb card for a samsung 420
Your camera is definitely compatible with SD cards up to a maximum capacity of 512MB. It was never hardware tested by the manufacturer with larger capacities and definitely cannot accept any SDHC cards (4GB and upwards); I have also tried one in the past with a 2GB SD card and it was unusable. Unfortunately Samsung have never actually published any hard and fast data stating what the maximum capacity is for the Digimax 420.
In summary then, you're good to go with 512MB SD, 1GB SD is a gamble and will either work or it won't (but won't harm your camera or the card), 2GB and above are not suitable.
Oct 11, 2010 | Samsung Digimax 401 Digital Camera
When i insert my 4Gig SDHC card into my Panasonic DMC LS2 camera , it gives a card error message , please check SD card ! What do i do ?
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 14, 2010 | Panasonic Lumix DMC-LS2 Digital Camera
Is a SDHC Memory Card 4GB compatible with my Canon Powershot SD600 camera?
Aug 26, 2010 | SanDisk 4GB Secure Digital High Capacity...
I have the JVC above and it requires an SD card. I inserted an SDHC card and it gave me an error. SD and SDHC are not the same? When I did try to but SD card only still on its label has SDHC. To be honest...
You are correct. SD and SDHC are not the same.
SDHC stands for Secure Digital High Capacity. It was a technical evolution which broke the 4GB maximum capacity of SD cards and allows up to 32GB. In turn they are eventually due to be superseded by SDXC cards (ecure Digital eXtended Capacity) which allow a maximum of 2TB.
May 30, 2010 | JVC Everio GZ-MG37 Camcorder
Can I use a 4GM SDHC card in my Samsung Digimax S800? The manual says "up to 1GB guarantied".
No. Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Oct 16, 2009 | SanDisk 4GB microSDHC Memory Card
Cant get sdhc card to format with kodak eashshare cx7430
Your camera has no support for SDHC, only SD - this in essence means you can put a maximum of 2gb card.
Good luck.
Apr 19, 2009 | Kodak EasyShare CX7430 Digital Camera
May 17, 2008 | Pentax Optio S5n Digital Camera
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
