Question about Refrigerators
Ixl super 70 space heater
24 hour timer stays on continuous ticking
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
SOURCE: the 24 hour timer stays on and I don't know how to
Lock button and F (light) i hate that thing.
Posted on Jan 11, 2010
  • 903 Answers
SOURCE: Kenmore Dryer 70 series
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Posted on Sep 14, 2010
jharwell668
  • 640 Answers
SOURCE: hayward pool heater h series
It could be that your gas connection has a blockage that is preventing adequate fuel for from getting to the heater. If that is not the case, try consulting your owners manual for these pool heaters. There is an online copy at the link below.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
machinetech7
  • 1344 Answers
SOURCE: kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Posted on May 01, 2012
Fridge isn't getting cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 12, 2013 | Washing Machines
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
The LCD (24 hour timer) is blank so the heater wont work
There is nothing you can do, turn on your oven if electric, or if gas open a window 4 inches and dont sleep with a gas burner running.
Oct 25, 2012 | Dimplex OFC2000TI Heater
Ice buildup on evaporator coils
Can you locate the model number of your Kenmore? The number should look like this 521.345678 and located around the inside of the fresh food section door.
It could be that the defrost heater came on the time you were watching bugt may have a bad connection or a defective defrost element. You need to test the heater for continuity to assure that the element is not broken. the defrost timer and defrost thermostat being new eliminates that as being the problem so I think your element or the connection is the most next likely cause, Let me know I don't mind helping, Thanks Sea Breeze
Defrost Heater Testing for Continuity
Jun 23, 2012 | Kenmore 25.1 cu. ft. Side-By-Side...
My automatic omega watch stops after 20-24 hours eventhough i am promised it should last for 48hours if worn continuously for 48 hours.
Almost all automatic wristwatches made today have an 18-24 hour "power reserve" when fully wound. A 24 hour reserve is actually very, very good. I can't think of a modern self-winding wristwatch that has a 48-hour power reserve because that would require a super-long or much larger mainspring than would fit in a modern watch movement / case. There may be some hand-crafted or super-premium watches that can do this, but only a very select few.
Manual wind railroad pocket watches, which were some of the finest and most accurate mechanical watch movements ever made, generally had a 40-hour power reserve. That extra capacity was created by using a large mainspring to store the extra energy. These mainsprings could be used because of the much larger size of these watches, compared to modern wristwatches.
If you are concerned about keeping your watch ticking, even when you're not wearing it, you might want to look at a "watch winder"--basically, a small watch case that rotates the watch for you, keeping the automatic winding rotor moving and the watch ticking. In addition, sitting at a computer all day will wind your watch much less than walking and otherwise moving around. Even though you're wearing your watch, if you're not moving, you're not winding it.
May 09, 2011 | Watches
Ice build up in the bottom of a woods upright freezer. have romvoed ice and taken hair blower to the tube and water drains. Does not solve problem ice continues to build up
ic Defrost Thermostat
This is the component that controls how long the heater stays on when the machine is in defrost mode. Say the defrost cycle is thirty minutes, the heater may only be on for ten of those thirty minutes on the timer controls. On Adaptive Defrost Controls, when the heater shuts off, shortly after the machine exits defrost mode. Basically if the heater only stays on for ten minutes, the whole defrost cycle will only be about 12 or 13 minutes longe is continueing to build up due to one of the defrost cycle parts not fucntioning properly this is the most likely piece to be causing your ice up issue do a continuity test on the thermostat to assure that it is working properly
Basically when the heater comes on, it starts to melt the frost on the evaporator. Once all the ice and frost is gone, the temperature behind the panel will start to rise. Once the temperature behind the panel rises to a certain temperature, the thermostat will break the current of electricity going to the heater. Bam, it shuts off and prevents your freezer from becoming a sauna, or an oven. I'm sure you get the drift. The heater is on the bottom of the evaporator coils and the defrost thermostat sits on top of the evaporator coils.
Defrost Heater
This is the last component in the defrost system. This one should be pretty simple. By now if you have read this far you should already know what this does and how important is it. Some defrost heaters are a coil of wire in a glass tube under the evaporator coils. Works like a light bulb basically. The other style looks like the bake element in your stove. They both get red hot either way and melt the frost
Defrost control or timer.refrigerator-defrost-timers.jpg Some refrigerators have a defrost timer. This type works like a clock. Every eight hours or so the machine hits the defrost spot and that's when defrost occurs
Some refrigerators have an Adaptive Defrost Control. This is what makes a refrigerator energy efficient. It varys the length of time it takes the machine to go into defrost. So instead of the energy hogging heater 240545401adc-board.jpgcoming on every eight hours, it may be 24 hours, 18 hours, 10.5 hours, who knows. It depends on how many times you have opened the doors, how long the compressor has run. This is good because the refrigerator may not need to go into defrost every eight hours. Now you are saving energy.
and lastly there is the fan also if it is not working will not allow the flow of air to leave the inside of the freezer. Continuity test can also be done on the heater as well and the least likely would be the timer to go bad in some models they have a board on the back of the machine instead of a defrost timer if you have any further questions please message me back and please remember to rank how this opinion has helped as well Thanks again Rick
Jan 15, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I bought a westek daily timer for a space heater. The issue is that it powers on at the desired time but does not then start to operate and heat- the equivalent of when you plug it in only. I want it to...
Your question is a bit hard to understand.
You have a plug-in timer.
It's connected to a space heater.
The timer powers ON correctly.
But for some reason the heater does not turn ON?
I think you should check the wattage of your space heater and compare it to the wattage of your timer.
A lot of plug-in timers are pushed to the limit at 1000Watts
Your space heater is 1200W or 1500Watts probably.
Buy an appliance timer to handle the space heater load.
Intermatic HB113C timer handles 2000Watts
It will be safe.
Set two on-off functions per day
http://www.smarthome.com/25071/Intermatic-HB113C-120V-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Nov 08, 2010 | Hardware & Accessories
The freezer is icing up again on my MSD2758GE fridge. How can I test to see if it the adaptive defrost assembly or something else?
Top of Form
Suspect the fault can be the defrost timer to confirm shut off the fridge, after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Maytag MSD2758GEB Side by Side...
Timer doesnt tick but works if moved manually
The timer has come to the end of it's serviceable life. Being mechanical, they wear out and are not designed to be econonomically fixed.
It needs replacing.
Regards
Jan 14, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
