Question about Coffee Makers & Espresso Machines
Krups error code PANNE OA - Coffee Makers & Espresso Machines
Error code OA on Krups EA8080
OA means that the sensor is not detecting any heat in the boiler. That means either the boiler is not heating or the sensor or sensor wire is detached from the boiler or the sensor has failed. The sensor is located behind the front display panel stuck in the front of the boiler and it has 2 thin wires in it with push on terminals.
Jul 17, 2018 | Krups Coffee Makers & Espresso Machines
I'm looking for an error code meaning that appear on my krups coffee machine the error code is "code error 02"
You will probably get some proper help if you identify the exact model. I don't expect "error 2" to mean exactly the same on every model Krups have ever made, narrow it down a bit for us please.
Mar 22, 2017 | Krups Coffee Makers & Espresso Machines
Krups coffee maker error code 01
The error code may be different for different models, you need to supply more info when asking questions, the brand is not enough, Krups have made hundreds of coffeemakers.
Mar 16, 2017 | Krups Coffee Makers & Espresso Machines
Krups ea 8250 error code 05
I have ea8250 krups machine . It gives me error code 05
Jul 29, 2014 | Krups Coffee Makers & Espresso Machines
Error code OA
Where do you get error OA on an XP4030, the machine does not have a display?
Oct 09, 2013 | Krups XP4030 Espresso Machine
Krups ea 8260 espresso maker error code 07
Error code 05 on my krups ea 8260. How to fix it?
Dec 24, 2012 | Krups Small Appliances Espresso Machine
Error code oa will not preheat
you need to get to an authorized service center.
Try http://www.smallappliance.com/repairsmain.asp?cur=USD
Mar 04, 2011 | Krups XP7230 Compact Super Automatic...
Code panne C 6000
fuser code..you have to replace the fuser unit
Jan 08, 2010 | Copystar CS-2550 All-In-One Printer
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Error code OA
Error code "OA"....machine thinks it has a faulty Laser unit. You can try a reset ( Menu, *,M..press ENTER.) if it resets GREAT.
If not and the code comes back,most likely Laser unit is defective.
Expensive and time consuming repair.
Sep 05, 2008 | Muratec MFX-2500 Plain Paper Laser Fax
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
