Question about Onkyo TX-SR601 Receiver
Hooking up computer moniter to tv through the Onkyo
Can this be done easier than if we didn't use the Onkyo at all?
  • 59 Answers
Re: hooking up computer moniter to tv through the Onkyo
Shouldn't be hard at the composite out (yellow RCA)into the Onkyo...the composite is not the best signal method for the TV (HDMI, SXGA, S-Video) but most A/V switchers only have spot for composite. IF you don't have composite on your PC might have to look at a different (i.e. new) video card that has support for it. Of course, you've haven't given me a huge amount of info so this is general info... Good luck
Posted on Aug 28, 2007
0 characters
3 Points
Would like to connect onkyo TX-DS494 to my television to play the television sound thru the receiver
To get the sound into the Receiver you don't need to go from the TV. On the back of the cable box there are a pair of audio outputs. Connect those to the inputs on the Onkyo. When that is done you need to select the input on the Onkyo to match the input that you have wired it to. You will then have audio come through your system.
Jan 08, 2015 | Onkyo Audio & Video Receivers
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
I have my Onkyo tx ds656 hooked up to my HDTV via the cable box. Everything works fine, except that there is a noticible delay in the syncronozation of the sound and the video. Is there any way to correct...
It's the nature of the beast. The TV has to process the digital video bitstream more than the receiver has to process the audio so the result can be a gradual lagging of the video behind the sound...
Some receivers have a sound delay control which you can use to try to sync them up. I didn
Jan 24, 2011 | Onkyo TX-DS656 Receiver
How do I hook up my Onkyo receiver to my dish network box?
Take the cables from the receiver to the tv and connect it to your Onkyo where it says "in", then take another cable and run it from your Onkyo receiver where it says "out" and connect it directly to the tv. Make sure you cycle the inputs on your receiver and tv, so you get sound and video.
Daniel Busa
DISH Network Customer Service
Jan 05, 2011 | Onkyo TX-SR505 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
Hooking up ps3
Check system in TV Format Setup:
Dec 28, 2007 | Onkyo TX-SR803 Receiver
Re: ONKYO with New LCD HI Def Television
Hi Lucylu
I don't have a solution to your problem -- but I do have the receiver and want to hook up my Plasma TV through the ONKYO TX-DS474 receiver. Its a great receiver but am not sure it will "do the job" being so old in the tooth.
Hope you found a solution!!
Nov 18, 2007 | Onkyo TX-DS474 Receiver
Onkyo TX-SR601 Receiver Logo
119 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
