Question about Kitchen Ranges
Defy STOVE DGS122
HOW TO REPLACE BAKING ELEMENT
revamos
  • 16 Answers
SOURCE: Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Posted on Apr 21, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
TaPuna
  • 70 Answers
Hey there. make sure the clock in on manual and not automatic is should show a little hand and not a 0 :)
Posted on Sep 07, 2008
duby1990
  • 370 Answers
SOURCE: Baking element
Pull the two screws out of the element (on the back wall) Turn the power off to the oven and then pull the two terminals off the element. Then check the ohms on the element. If no ohms change the element and your fixed. The element is usually always the problem. You can get the element at your local parts store, or at sears online via model number. If you go to your local parts store take the element with you and the model number.
Posted on Nov 19, 2008
SparkyNZ
  • 43 Answers
SOURCE: Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
Posted on May 11, 2009
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
While baking my wife noticed sparks coming out of the baking element or coil. can we continue to use the stove top or should we leave it unplugged.also how much does it cost to replace the element
It sounds like the element shorted out and needs replacement. I would not continue to use the oven, although it should be ok to use the stove.
It's difficult to say what a new element plus installation will be, but you can call around and get estimates. Have the model number, type and serial number available if possible before you call.
Dec 12, 2009 | GE Spectra JBP78 Electric Kitchen Range
FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Aug 24, 2009 | Ovens
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Baking element
Sep 05, 2008 | Kitchen Ranges
Baking element
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Kitchen Ranges Logo
19 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
