Question about GE JKP85 Electric Double Oven
Turntable not turning and microwave not working
Microwave has stopped working - plate no longer turns and microwave is not heating. I've seen other postings where the door switch was the problem. Is there as way to bypass the door switch so that I can be sure this is the problem?
  • sean_lui Nov 11, 2007
    Tuntable would not stop turning after the time expired. It eventually stopped after closing the door a couple of times. Now the lights turn on starting the microwave, but the turntable does not move nor the food heats up.
  • Anonymous Oct 29, 2008
    Same problem... where are the wires/switches?
  • 640 Answers
The switches are on the left or right side or both (there may be two).locate them and theres 2 wires on the switch.jump them out.if there bad replace them as it would be a hazard issue for radiation not to.
Posted on Aug 28, 2007
SOURCE:
Microwave is not make food hot
Hi.
The wave emitting part inside the microwave oven is called the magnetron. The waves emitted by the magnetron generate heat in food. When the microwave is running, turntable turns and light comes on but there is no heat it means that either the magnetron is faulty or the magnetron is not getting power. When the magnetron is not getting power parts such as the high voltage diode or capacitor must be tested or replaced. Testing and repair must be carried by a technician. Here some general troubleshooting: http://www.fixya.com/support/r2096491-microwave_works_normally_but_not_heat
Regards.
Ginko
Sep 05, 2011 | Whirlpool Ovens
Do you take the turn table out when using both the microwave and the oven (combie)
No; if you're using the microwave you need to leave the turntable in to ensure the food heats evenly.
If you use just the oven or grill you can still leave the turntable in; there's no need to remove it. But you could remove it if you wanted.
Jul 25, 2011 | Ovens
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
The microwave oven is on and sound of the motor is audible. the glass plate inside does not turn and there is no heating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 13, 2010 | Ovens
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
GE Microwave Model JKP85 Plate does not rotate
Usually this is a bad turntable drive motor in the floor of the microwave but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
TheRepairGuru ----- www.repairclinic.com
Click here For: GE-Microwave-Parts
Jan 26, 2009 | GE JKP85 Electric Double Oven
Whirlpool Over-the-Range Microwave Not Heating, Model #MH7135XEQ-1
This is not something you'd want to repair. You are better off getting a new one. It is a lot of work and a little risky
Apr 12, 2017 | Ovens
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? [email protected]
Sep 11, 2007 | GE JTP85 Electric Double Oven
GE JKP85 Electric Double Oven Logo
432 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
