Question about Ariston Technologies L63 Free-Standing Dishwasher
Stuck on 12 hr delay
Hi, My Ariston 63 is stuck on 12 hour delay and no matter how many times I press the timer button it does not change.
2 Suggested Answers
SOURCE: when starting wash delay timer flashes on and off
Hi Danny, did you solve this as mine is doing he same? regards
Posted on Feb 04, 2011
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Radio Shack atomic clock 63-1438. How do I set it for 12 hr. time rather than 24 hr.?
Some clocks of this type have a 12/24 selection switch on the back.
Dec 28, 2015 | Home
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Setting timer on window unit to turn on and off
Hi Jessica Yacopino - Generally speaking, Frigidaire air conditioners timer option typically have the same procedure. The unit must be in the ON position for the timer delay stop option. For delay start, the unit must be in the OFF position. First, press time button. Then to adjust timer setting, tap or hold the UP arrow or the DOWN arrow to change delay timer at .5 hour increments, up to 10 hours, then by 1 hour increments up to 24 hours. The control will count down the time remaining until start (8, 7.5, 7, etc.). The Delay Start mode automatically selects cooling with maximum Fan Speed. The temperature maintained will be the same as previously set. To change the set temperature, press "COOL" then Up or Down arrows until the desired temperature is indicated on the display. After 5 seconds, the control will automatically change the display back to the hours remaining until the unit will start/stop. PRESSING the unit On/Off button at any time will cancel the Delay Start/Stop function. The Delay Start/Stop Feature will work until the unit either starts or stops. Once that happens the above steps have to be repeated again.
Oct 03, 2012 | Frigidaire FAS257S2A WallWindow Air...
I have just bought the yardworks 2 zone water timer from Canadian Tire and there are no instructions anywhere. I have managed to get it to work for one minute and I have it set to do the same in one hour...
Delayed Watering
You can delay the first watering cycle of each watering zone by up to 12 hours by using the small button at the bottom middle of each zone area. Press the delay button 1 time for each hour you wish to delay the first start time. The "Low Battery" light will illuminate when you press the button. The maximum delay is 12 hours.
For example, if you are programming at 4:00 in the afternoon and you want your timer to water every 12 hours, but you want the first watering of the day to start at 6:00 a.m., press the Delay button two times. Without the delay, the first cycle would have occurred 12 hours after the timer is programmed (4:00 a.m.). The delay feature changes that to 6:00 a.m. The timer will then water every 12 hours after that.
Aug 02, 2011 | Garden
Changing from 24 hr system to 12 hr system
  • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
  • Make note of the hour if you don't have another clock handy
  • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
  • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
  • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Mar 10, 2008 | Timex 27191 Wristwatch
Ariston Technologies L63 Free-Standing Dishwasher Logo
55 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
