Question about Car Audio & Video
I get power but no sound could this be factory amp if so where is it located.. And where could I get an accurate wiring diagram.. Also is there two fuse boxes one by the battery and was told one under steering column but can't find it
    Problem Solver:
  • 6 Answers
Your stereo plug should include (yellow) constant power with a cylinder fuse, (red) REM or "remote" power getting power when the ignition is switched on, (black/grey) ground, usually any other with some color and a matching wire with a line on it is positive and negative speaker wire.
Posted on Jul 19, 2013
  • Brady Oexmann Jul 19, 2013
    I would grab a test light, ground it, and check your speaker wires. (Optional) multimeter can do the same. If you have a sub, test your third party amp power supply and auxiliary cables. (Aux using ohms setting)
    Three common fuses are one under the good (10amp) one under steering column(10amp) one on yellow wire of radio from the back (3a-5a). If you are recieving power, all of your fuses should be fine. I would simply check your speaker wire connections.
2 Suggested Answers
ltfrc
  • 227 Answers
SOURCE: Changed battery cable now radio will not even come on.
When you said inline fuse I get the idea that this is not the original radio. Do you have power on the inline fuse? The 50 amp fuse you checked is a bit much for a radio. There may be a smaller fuse in another fuse area of what car type you have. If you do not have power at the inline fuse find some where you do have power (12vdc) and connect to it. If you have power at the in line fuse check the ground wire. If you have a test light or someway of checking for power test all fuses everywhere. If you have a fuse location guide for this vehicle look for the fuse for radio. If it was a add on or after market radio they probably caught power from the original source That is fused under the dash.
Posted on Jan 14, 2009
99 regal concert sound II problem
you wired incorrectly and burnt the amp in the sterio. next time just pay $15 and buy an adapter. plug in and your done.
Mar 15, 2013 | Cars & Trucks
Need color code diagram for factory 8 speaker (this number also includes door tweeters from factory) system in a 4dr 1999 chevrolet tahoe. found basic GM wire diagram, but my system is different due to the...
On my 99 4 door the factory amp is powered by a hot pink wire in the truck harness. I hooked the cont. power for a motorized ant. to it and all 4 speakers work. I'm going to check today to see if they work correctly because I found this out late last night and only had it on for a few minutes. I've read that there is a harness for this that apparently you have to specifically ask for at a car audio shop. hope this helps.
May 25, 2010 | 1999 Chevrolet Tahoe
I need the wiring diagram for a 96 Geo Tracker
1996 Geo Tracker Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
Nov 22, 2009 | 1996 Geo Tracker 2 Door
'04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Sep 05, 2009 | Car Audio & Video
Looking for 1996 ford mustang wiring diagram for stereo
things to consider:
Does it have a factory amplifier?
Is the factory harness still present?
Does it still have the speakers present?
You are going to only have a certain amount of wires... If the factory harness is still there you can simply purchase an aftermarket or just look at one in a local store on what wires are what.
you would have your:
gray and gray w/ black
purple and purple w/ black
green and green w/ black
white and white w/ black
these are normally used as an after market clip on harness for that factory wiring. (left front, right front, left rear, right rear)
Obviously your going to have the constant (yellow), ignition (red) and the ground (Black);
so the others would be either a remote (amp or power antenna) usually white with blue strip and dimmer normally orange for the after market harness, and the others will be the speakers.
What you COULD try is using a 9v battery and picking up the wires that are solid and striped and touching them to the 9v battery.
When you find the two that make that speaker make a popping sound you have found that speaker.
Once you have found the speaker that pops, you should be able to take it out and look at the color of the wires to make sure you will have the pos and neg for each speaker correctly set.
You dont want some speakers being in phase while other are out of phase. if so the sound wont be right.
Mar 27, 2009 | 1996 Ford Mustang
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
2002 Chevy Cavalier audio wiring diagram
to the guy who is looking for the wire diagram, you can buy a wire kit for the stereo connection for about $60 from best buy or some other place like that. your car's door ding and some other things wont work with out it. hope that helps you some.
May 30, 2008 | Car Audio & Video
No sound comes out of speakers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
May 22, 2007 | Dual XDM6825 CD/MP3/WMA Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
