Aircoditioner freezes in frontier
It freezes up in the front how can i fix that? its a kenmore
    New Friend:
If used to cool without freezing it have less refrigerant or the fan is not working or lost of the blade or the coil is dirty not enough air going around it
Posted on Jul 17, 2013
  • 2 more comments
  • Jhonny Guns
    Jhonny Guns Jul 17, 2013
    Ok thank u
  • Jhonny Guns
    I cleaned it really good took it apart hosed it down and cleaned it really good...
  • Jhonny Guns
    If its refrigerant how do i add to it
  • mathew Jul 17, 2013
    What heppan after you clean it . Is it was dirty .
Where are the freeze plugs for a 2000 Nissan frontier pickup with a four cylinder engine?
Freeze plugs are usually at the bottom of the engine. One set on each side of the block.
Dec 17, 2014 | 2000 Nissan Frontier
Where are the freeze plugs in a 2000 Nissan frontier with a four cylinder engine and automatic transmission?
In the side of the motor, also called welsh plugs there could be one in the back of the head as well.
I have a Kenmore Coldspot Model #78187891, with a leaky icemaker problem. The icemaker seems to leak near the front of the icemaker (closes to freezer door) and makes these stalactite structures. This...
Most likely ice maker is the problem and would need replacing. Water valve is letting to much water in but the amount of time solenoid stays open is controlled by the ice maker
Sep 28, 2017 | Kenmore Refrigerators
How can I fix my old Kenmore refrigerator which is freezing everything inside?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Kenmore Refrigerators
98 frontier ac quits after about 15 min on hot days.
Check the drain pan to make sure that it not plugged with dirt in the drain hole which could cause the evaporator to freeze and then it won't blow cold air as it solid hunk of ice
Mike
Jul 08, 2009 | 1998 Nissan Frontier
NISSAN FRONTIER 2003 THE AC DOESN'T CUT OFF IS RUNNING ALL THE TIME AND THE HOSE GOT FREEZE
These motors a designed so that as long as you have the fan on the compressor will cycle. You could have a host of problems. If you have a leak the compressor will work harder trying to recondense and can freeze up the lines. Or the temp control is shot. Does it freeze up even with the A/C switch in the off position?
May 10, 2009 | 2000 Nissan Frontier
Worried about winter storage
Extreme low temperature may effect the operation of the electronics, but unless you plan of using them in a freezing environment there will be no ill effects from the cold. These units are shipped in unheated trailers all over and routinely are exposed to freezing temperatures.
Thanks for using Fix Ya, please take the time to give this solution a Fix Ya rating.
clarkco
Feb 06, 2009 | Kenmore 44102 Front Load Washer
My 2003 nissan frontier 4x4 overheats when the AC is on and I am move at a slow pace. Why?
I had the same problem one hot day waiting in a McDonald's drive-thru but it never occurred again since I changed the anti-freeze. Some say it is just caused by air in the system and changing the anti-freeze may have coincidentally (but maybe temporarily) cured the problem. That was 2 years ago and I may have problems this summer. It doesn't seem right to need a new radiator on a product this new - maybe when the other guy changed his he got rid of his air and that fixed it.
Jul 09, 2008 | 2003 Nissan Frontier Crew Cab
Needs instructions to remove the front panel to replace the microswitch near water dispenser arm
Kenmore model#10658562891 side by side refirigerator.
Need instructions on how to remove front panel to check or replace the heater that keeps Ice from freezing in the Ice chute.
Jan 04, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
