Our 72 in Mitsubishi tv keeps shutting off after a bulb replacement
    Champion:
  • 247 Answers
Ensure the lamp timer is reset otherwise next the lamp will completely be damaged get to the net and get the lamp reset procedure for that model and ensure its done this will solve tthe problem
Posted on Jul 18, 2013
4 Suggested Answers
  • 1456 Answers
SOURCE: Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Posted on Jul 04, 2010
ladywinn
  • 5138 Answers
SOURCE: 72 in shuts off 3x every 10 min.new bulb 7 th one
You need to check on the power supply board for Bad Capacitors they will be vented,swollen, or puffed up on Top. 680uf 10v,330uf 10v 3300uf 10v 2200uf 10v,
Posted on Sep 01, 2010
SD Tech
  • 14553 Answers
SOURCE: We have a mitsubishi 735 series tv. When we power it on the mitsubishi sign comes on then the tv shuts off. We replaced the lamp bulb but that wasn't the problem. Any suggestions
Most of these sets that come on with the blue screen and logo and shut off shortly after may have two resets---I can tell you the soft reset.
Turn set on with the Mitsubishi remote and when screen comes up blue with logo:
Menu, 1,2,3 enter
This applies to most of these sets.
Posted on Mar 14, 2012
How do I fix a mitsubishi tv that shuts off and has a steasy red light
Replace your lamp. Make sure its a real Osram bulb and not some cheap knock off. These folks have Osram bulbs and a 6mo warranty. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
Sep 26, 2016 | Mitsubishi WD Televison & Video
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
I have a Mitsubishi 60inch 60737 replaced the bulb last month.now it keeps cutting off,cleaned the filter before.someone said to reset bulb timer,how do I reset it.
The Lamp timer will not cause it to shut down. The timer should have been reset when you first turned the TV on after replacing the bulb. Make sure your bulb is an Osram brand bulb. If not, then you do not want to use it as it may not be very good.
May 27, 2015 | Mitsubishi Televison & Video
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Menu, 1,2,3 enter
Mar 14, 2012 | Mitsubishi WD-60735 Projection Television
Keeps shutting off
First try to check the bulb if not broken if broken or damage try to replace it, after you replace the bulb you should reset the lamp timer. Good day and best regards.
Aug 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
72 in shuts off 3x every 10 min.new bulb 7 th one mitsubishi 72 in
Sep 01, 2010 | Mitsubishi WD-73927 73" HDTV
GOODLUCK
Jul 04, 2010 | Akai PT61DL34 Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
