What is the btu for G83-100D2C4-2 - Heating & Cooling
What tonnage is it
not sure what you want so i will give a general answer.
tonnage is equal to BTU ...
so it you have a....
12000 BTU that's a 1 ton AC
24000 BTU that's a 2 ton AC
36000 BTU that's a 3 ton AC
and so on and so on just look on the tag for the BTU's
Feb 01, 2016 | Heating & Cooling
What is m6x06f2a btu output?
Features
  • Cooling Capacity (BTU) : 6,000 BTU
  • Maximum Cooling Amps : 5.6 Amps
  • Maximum Cooling Watts : 618 Watts
  • Heating Capacity (BTU) : 0 BTU
  • Maximum Heating Amps : 0 Amps
  • Energy Efficiency Rating : 9.7
  • PTAC : No
  • Window Type :Standard
Aug 04, 2015 | Maytag M6Q10F2A Air Conditioner
Btu rating on natural gas meter
Gas meters are usually rated in cubic feet per minute (CFM) not BTU. there are 1027 BTU per cubic foot so do the math. Try the link below Btu rating on natural gas meter
May 14, 2014 | Rheem EcoSense by 7.4 GPM Tankless Water...
KW to BTu's
To convert KW to BTU use the following:
1KW= 3412.142 BTU/ hr
Hope this helps.
Bob
Jan 17, 2014 | Intertherm 56000 Btu Gas Furnace
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
WHAT DOES 12000BTUh MEAN OR REPRESENT IN AIRCONDIONING terMS? eg 12000 or 10000
I found this explanation which I certainly couldn't improve on.
The British thermal unit (BTU or Btu) is a traditional unit of energy. It is approximately the amount of energy needed to heat one pound of water one degree Fahrenheit. One Btu is equal to about 1.06 kilojoules. It is used in the power, steam generation, heating and air conditioning industries. In scientific contexts the BTU has largely been replaced by the SI unit of energy, the joule (J), though it may be used as a measure of agricultural energy production (BTU/kg). It is still used 'unofficially' in metric English-speaking countries (such as Canada, the United Kingdom), and remains the standard unit of classification for air conditioning units manufactured and sold in many non-English-speaking metric countries.
In North America, the term "BTU" is used to describe the heat value (energy content) of fuels, and also to describe the power of heating and cooling systems, such as furnaces, stoves, barbecue grills, and air conditioners. When used as a unit of power, BTU 'per hour' (BTU/h) is understood, though this is often abbreviated to just "BTU".
I located it at this site all credit for this info is:
http://en.wikipedia.org/wiki/British_thermal_unit
Hope this is what you need,
RSMITH972278
P.S. PLEASE RATE ME !
Oct 18, 2009 | Heating & Cooling
Do you know the btu rating for Teledyne Laars Mark V
All heaters have a data plate. Often the model # is the BTU's. For example, H400 is a 400,000 BTU output. The plate is on the inner firewall. All heater have different BTU's.
Aug 22, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
How long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
Jan 18, 2009 | Dyna-Glo RMC-8001SS Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
