Question about jetta harness for door fuse box/relay plate for fuse
Where is the fuse box on a 2005 Jetta - jetta harness for door fuse box/relay plate for fuse
2 Suggested Answers
  • 977 Answers
SOURCE: I need fuse box map for a 2005 volkswagon jetta
you might find the fuse diagram inside the fuse box cover under the hood.....hope this helps....cheers
Posted on Jul 31, 2010
How do I locate fuse chart for 2005 jetta tdi. Not included in manual.
I don't own a Jeta, but every car I've worked on made in the past 20 years has a Fuse Chart printed on the underside of the fuse box cover. They know that the information is too important to only print in the owner's manual which often is not available.
Mar 09, 2015 | 2005 Volkswagen Jetta
Where is fuse box?
Where is fuse box Anon. fuse/relays are under hood and in dash. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to check and replace fuse 2005 Volkswagen
VW Jetta Fuse Box Location Video
Volkswagen Jetta Power Outlet Problem and Solution
Jan 29, 2014 | 2005 Volkswagen Jetta
And where is fuse box located
fuse box on a jetta is on the drivers side of the dash board open the door use a screw driver or a hard knife to take off the panel GL
Jan 04, 2013 | 2005 Volkswagen Jetta
Fuse panel diagram for 2005 VW Jetta 2.5
i am having trouble with power windows at first it was the switch and then the motor now that i replace both it won't work at all gas cap wont open and windows dont go up i check both fuses boxes and fund no burn fuses can you please help is for a 2005 VW Jetta 2.5
Feb 24, 2012 | Cars & Trucks
2005 2.5l volkswagen jetta 4 door i need fuse box diagram or service manual pdf anyone know where i can get this ?
Hey man. You can pick up a repair manual for your jetta at any local auto parts store. Also on your fuse boxes when you remove the panel covering the fuses, on the backside should be a label that will tell you what amp fuse and what each fuse goes to in the car. hope that is helpful.
Aug 22, 2011 | 2007 Volkswagen Jetta 2.5 Sedan
Jul 26, 2010 | 2005 Volkswagen Jetta
Could yoy please provide me with a fuse box layout for the vw jetta 2007 because when i turn my ignition off the clock and the trip reset themselves
On page 301-302 of the owner's manual there is a LIMITED fuse box layout. Fuses are located on the driver's side in the dash on the side and under the hood next to the battery.
Oct 12, 2009 | 2007 Volkswagen Jetta 2.5 Sedan
Windshield washer fluid pump quit. 2005 Jetta
I have a 2003 Jetta and the fuse box is between the dashboard and the drivers side door. There is a lid that covers it on the dashboard side. Inside there is a diagram/fuse card. The card has one top rectangular series of fuses numbered 8 through 23. Below is a square series numbered 24 through 44. The washer fuse is number 24 on the top left of the bottom square series. For me, I checked the fuse and it was good, therefore I am assuming that my pump is dead.
Apr 22, 2009 | 2005 Volkswagen Jetta
jetta harness for door fuse box/relay plate for fuse Logo
42 people viewed this question
Top Volkswagen Vehicle Parts & Accessories Experts
dadr
Level 1 Expert
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Vehicle Part and Accessory Expert? Answer questions, earn points and help others
