Question about Cell Phones
Samsung wave 7223
The phone was purchased just 1 and half year back only. Without connecting to USB port it is showing connected status on the screen. I am unable to call anybody because whenever I switch on the phone this "connected" status displays. Battery also totally empty. I had charged it fully the previous night only but overnight this is status. Wondering why go for such a costly phone (for my status). I paid Rs.13000/- for the phone.
  • 143 Answers
SOURCE: charging alien battery?
if you had given for servicing anywhere in any other shops other than the authorized service centres, they might have changed the batteyr. try top get that problem solved.
Posted on Aug 10, 2009
Raysagem
  • 1017 Answers
SOURCE: Nokia 6300 does not boot up when started
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Posted on Mar 26, 2008
SOURCE: not charging
your phone charger might be the primary problem...
Posted on Jun 22, 2008
AAHA 2712
  • 64 Answers
SOURCE: Unable to connect my samsung star phone using pc studio mode...
is it tellin "pc studio is performin a time consumin operation. try again later"...... i'm havin the same problen
I could connect after tryin several days:(....
Posted on Aug 11, 2009
  • 4 Answers
SOURCE: unable to fix com port for lg u8330 camera phone
Plug in the USB cable. Use the LG Installation disk to install the driver.
if you do not have the driver search Google with these words " LG U8330 Driver Installation disk" and you will find it or you can download the driver here:
http://www.nodevice.com/driver/download.html
Remember after you install the driver open the LG Phone Manager
and click on open COM port. The correct COM port has a little * beside it.
E.G. *11 or *03 etc., etc. then click on CONNECT.
Posted on Aug 17, 2009
Hi....I had purchased a kenwood dpx u5120 and have been using it for the last 1 year without any problems. Now when i connect a usb or my phone, it says "NA DEVICE". I tried changing the usb, still it...
Hi Abdul,
make sure your usb device is working and use the user manual of kenwood to find the supporting file format.FAT32,NTFS,and the file is you are going to play is compatible with your set,.
please check the usb port connection pins for corrosion .if yes clean it with compressed air or electronic contact cleaner.
if it dosent work .
go for the Warranty.
regards,
Nuwan
Jan 09, 2014 | Audio Players & Recorders
How to connecte with pc
after plugging the usb cable you need to go to menu Settings Connectivity USB USB debugging.
or just choose to see the memory and set
Settings Connectivity USB Mass storage Set.
Or yhou can use Samsung Kies, which you need to install
In Menu mode, select 1 Settings Connectivity
USB Samsung Kies Set.
Mar 26, 2012 | Samsung Wave 525 Cell Phone
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
Dear Sir/ Madam, why i cant play farm ville on my samsung wave 525. While going to play they are showing a message that you need to upgrade your flash player. Plz revert back asap Thanx, Milind.
Farmville requires Flash 10 and your phone does not support it.
You can try updating the firmware on your phone to see if it will work. To update your Wave 525:
  1. Make sure you have Samsung Kies installed.
  2. In the phone, Go to Settings > Connectivity > USB > and change it to "Samsung Kies"
  3. Plug in the USB and wait for Kies to detect your phone. Once it does...if there is an update you will see "Update Firmware" on the bottom. Click it.
May 07, 2011 | Computers & Internet
Samsung Wave GT-S8500 will not connect to Win 7 Pro despite updating to the latest Samsung Kies software suite Ver 2. Problem with MTP USB driver. Windows says "latest driver is installed" Why...
make sure that
1. you have stopped all the applications in the taskmanager
2. you have chhanged the usb conncetivity to ' Samsung Kies ' in
settings>conncetivity>usb
Feb 08, 2011 | Samsung Wave S8500 Smartphone
SAMSUNG 40GB HARD DISK MOTOR IS NOT ROTATING AND SYSTEM SHUTDOWN IMMEDIATELY WHEN IT IS CONNECTED TO PC
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 10, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
How could i install samsung on my computer without using cd installer
If your computer does not have a CD drive then -
There are two methods.
1. Purchase or borrow an USB external CD/DVD drive connect it to the mini laptop's USB port and install the software from this drive.
2. Use a different computer and copy the contents of the CD to an USB memory stick and then plug it into the mini laptop's USB port and install the software from this USB memory stick.
OR
If you have lost the installation CD then I suggest you go to the Samsung WEB site and download the installer file for your model cell phone.
Mar 24, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Samsung sgh j700 phone shows up as mass storage device
check the pc connectivity settings on ur phone.
make sure that ur using the 2.0 port of ur computer
dont use front usb ports cpu. use rear ports. they are faster.
if still problem persists. try below
conect ur phone to usb. now without disturbing the connections switch off and then on the phone. now there may be chances.
samsung sofware could be corrupted due to virus on ur pc. remove all the viruses then freshly install suit
Dec 09, 2008 | Samsung J700 Cellular Phone
Hi just purchased Samsung j700 mobile phone. Trying to connect to PC with USB - seem unable to get driver to work - even the one on the disk?
that's the link with driver for samsung SGH J700 works perfectly with my phone
http://www.samsung.com/au/support/download/supportDown.do?group=mobilephone&type=mobilephone&subtype=megapixelphone&model_nm=SGH-J700&disp_nm=SAMSUNG%20J700&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=01011800
kisses all :*
May 18, 2008 | Cell Phones
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
