Question about Ducane Oil Fired Furnaces Upflow With Belt Drive . Luf Serie
The patriot 80 plus oil furnace
What is the age of my oil furnace serial number 3286A032
I am trying to find out the age of my upstairs furnace. I had three contractors come out, one said it needed to be replaced, and two other one said only one part needed to be fixed but they were different...
it was made in 02 of 02. first three letters/numbers correspond to model # next 4 are year and month of manufactuer the remainder are production codes.
Have a great day!
Dec 27, 2017 | Heating & Cooling
How do I find the age of a Nortron 21B20 furnace?
The age will be in the serial number
Jun 25, 2014 | Heating & Cooling
How old is a ruud furnace model number ugaa- 08KC, ser. number RN3D104F18794988
Hello, The model number for Ruud/Rheem equipment is located in the 12-13 digits, these appears to be a 1994. I have seen some furnaces with an age older than when the home was built (a 1995 furnace in a home built in 2000), so good job checking the serial number. This gives you the age it was manufactured.
Hope this helps James
Apr 03, 2011 | Heating & Cooling
How old is my Coleman Evcon Furnace, Modle Number: DGAT056BDE? I can't seem to find a Manufacturing date sticker. It was claimed to only be a year old, now living here a year it would now be 2 years old. ...
The Serial Number would really help in defining how old your Coleman furnace is. The model you have is used predominantly in manufactured housing. To find the Serial Number, you will need to remove the upper shroud of the furnace. There should be a sticker or plate on the back of that shroud of just inside the housing of the furnace, that will give you the Model # & Serial #. Armed with that, you can do a little detective work, as to it's age.
Mar 03, 2011 | Coleman Heating & Cooling
Looking for age of Furnace. Model number appears to be 3010 100n. The serial number appears to be cn3 d108 50972 7055.
Not knowing the Brand, I am taking a educated guess, but it looks like it was made in the 50th week of 1997, 100,000 BTU furnace.
Good luck,
Paul Gibson
Apr 06, 2010 | Heating & Cooling
Is a patriot heater comparable to a goodman heater
The Patriot 80 is an oil furnace made by heat controller, To my knowledge Goodman (aka AMANA) does not make an oil furnace.
Feb 23, 2009 | Goodman GMS90703BXA Heater
Furnace blower motor dose not shut off.
Do you think it might be the relay switch
Feb 04, 2009 | Goodman GMS90703BXA Heater
Ducane Oil Fired Furnaces Upflow With Belt Drive . Luf Serie Logo
125 people viewed this question
Top Ducane Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Ducane Heating and Cooling Expert? Answer questions, earn points and help others
