Question about Dryers
280ss seemed to have lost ability to vary speeds . ONly run at high
    Genius:
  • 1,617 Answers
Check your capacitor.
Posted on Jul 17, 2013
I have a toro snowblower with a 2 cycle engine. When it's just running under no load it seems fine(maybe a little too high of rpm). When it starts throwing snow it gradually slows down until it quits...
It sounds like it is running lean. Back out your carbuerator adjustment screws a quarter turn counterclockwise. These settings should be 1 and a quarter on low speed (closest to engine block) and 1 and a half on high speed (farthest from engine block). These are starting points the adjustment may vary a little eigther way. Never adjust for max rpms that is too lean and will cause engine failure. Hope this helps ya.
Dec 22, 2010 | Toro Garden
My ProForm 750 only runs at low speed. Varying
If u r seeing the increasing variation takeing effect on the panel but the speed does not increase in real, then there is nothing wrong with the push button for sure.
what it could be is ,
1. Your motor is getting overheat quickly and does not accept the higher speed commands.
2. it could be a belt slip also (do u hear any extra noice / vibration when u increase speed)
3. next time, pls unplugg the unit for atleast 4 hrs and when u start after that increse the speed very next moment and see if it works. if it does increase this way then it is time take look first on the belt ans then check the motor.
Good luck.
Jul 25, 2010 | Proform iLog 750 Treadmill
2005 GMC Envoy XL High Speed Blower not working
if the other speeds work it is probably the blower resistor; if applies varying resistance to the voltage running the blower; this allows the fan to run at different speeds; should be located very close to the blower motor; behind a panel under the passenger side of the dash
Jun 27, 2010 | 2005 GMC Envoy Xl
Engine speed varies
If the unit was stored for a long period of time (6-12 mo.) with gas in it, you may have a gummed up carburator. This is the most common problem with generators (lack of use)
The carb. would have to be removed & cleaned, specificly, the high & low speed jets
Sep 04, 2009 | Coleman Sport 1850 Generator
Idle speed engine dies when throttled
It does sound like its getting to much fuel, or the lack of air. Air filter ok? If it is you might need to have a compression check done to see how the piston rings are.
Jul 03, 2009 | 2001 Honda XR 250 R
Ground speed slows under pull at high variable speed settings.
Take off the plate around the shift lever between your legs and take a look at the belts. Most likely they will be in poor condition. You can even leave the trans in neutral, start the engine and move the speed selector through the gears and observe the belts in action. They do the same in neutral as in gear when you let out the clutch with the engine running. You should be able to see what the problem is, It will either be one or both of the belts or possibly the needle bearings in the vari-speed pulley itself,
Jun 01, 2009 | Mtd Garden
I have a Ridgid 24V LI Hammer Drill. It was working fine and then suddenly it has lost lost torque. It sounds fin and seems to run fine but anything beyond screwing in a wood screw it just clicks like...
Make sure the speed lever is not in between speeds, if not, time to get a new clutch/tranny or take it back to Home Depot if its new. I think it comes in one piece. Please rate me.
Apr 07, 2009 | Drills
Speed varies on its own
You must replace the speed control module. Any Makita service certer can supply you with the proper parts.
Mar 08, 2009 | Makita 7" Electronic Sander - Polisher...
Barely any heat coming from vents blower motor working
check the coolant level & condition of antifreeze make sure it is not dirty/rusty/muddy if thats ok try a new thermostat & radiator cap if the antifreeze is muddy you may have to blow out the heater core
Mar 02, 2009 | 2002 Ford ZX2
Dryers Logo
35 people viewed this question
Top Dryers Experts
