Question about Mackie SRM 1801
Thermal overload and overlimit lights stay on and wont switch to green
    Sergeant:
  • 357 Answers
In short. It's knackered.
Posted on Oct 31, 2017
I have Behringer xenyx 1622fx , It will turn on the power but a few minute the power will turn -off , Please help me to solve the problem of this unit in power supply section or other section.
Here is your schematic:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down and find link "Get manual" and click to download.. IGNORE other download links they are for third party viewers. Power supply is on page 11. This is a switching power supply running from line voltage. For personal safety USE AN ISOLATION transformer when working on it. First thing is to measure all the voltage outputs before and during shutdown. Switching power supplies often require use of an oscilloscope to repair. The three terminal regulators that follow the main switching supply each have thermal shutdown so if one of them is being overloaded it will shutdown and that voltage will drop way down. Use great caution when working on the supply!!!
Jul 20, 2012 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Subwoofer ain't doing anything on peavey triflex
Could be a few issues. If it is powered up when you plug it in, it might have a short circuit protection that shuts it down, or a thermal overload that is over sensitive. It might also be an issue with the cable you are using to connect it, from a broken wire to one that has a plug just slightly too long- there are 5 different tip lengths.
This also assumes the input itself is not being over driven, and that the output is not shorting out either..
Jun 10, 2012 | Music
After five minutes, the Tonelab ST turn off, and turn on again, after this, the display screen shows "5F" (or something like). After 10 seconds this happens again, and still happen. Can be valve...
What it sounds like is that the thermal overload protection is engaging because there is a component that is overheating. I don't know what the operating voltage is of 12AX7A/ECC83 but I would imagine that would be one of the hottest components in the chassis along with the switching power supply. There is an issue with your pedal however it is tough to say without looking at it. Sorry I couldn't be more help. Good luck!
Jun 12, 2011 | VOX ToneLab ST Modeling Effects Processor
I NEED TO REPALCE THE TRANSFORMER FRO MY BANDIT 112.
It is unlikely the transformer is bad, Some of these have a thermal fuse in the windings. Usually failed components overload the power supply and blow the main fuse.
May 30, 2011 | Peavey Bandit 112 Guitar Amplifier With...
My clean channel wont turn on. Light just stays red on distortion.
Insufficent information !!! Are you controlling this by the footswitch or the onboard switch? If the onboard switch and you HAVE at some point used the footswitch, likely the contact on the footswitch jack has failed that transfers control to the internal switch. If you haven't tried the footswitch see if that has control. I can send you the link to the schematics if you know how to read them. Here they are:
http://elektrotanya.com/marshall_mg250dfx.pdf/download.html
Scroll down to the little link that says "Get Manual" and click on it to download.
Apr 15, 2011 | Marshall Amplification Marshall MG250DFX...
Piano nova digital piano wont switch on. Green light is on on adapter but power switch does nothing.
Verify the cord from the adapter to the piano is not broken (common occurance) using a voltmeter at the connector.
Then verify the connnector is seated in the piano.
Apr 24, 2010 | Music
I have a 2600 peavey amplifier and when i turn the volum up it cuts off for about 2-3 seconds what i need to do
check that the cooling fans are working. if they are not then you are probably triggering the thermal overload protection.
Nov 08, 2009 | Peavey Pv 2600 Power Amplifier
Mackie SRM 1801 Logo
172 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
