Question about Magnavox DV220MW9 DVD Player VCR
Dvd/vcr player manufacturers code - Magnavox DV220MW9 DVD Player VCR
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
Jan 01, 2016 | Panasonic Televison & Video
Codes for oneforall
It is my pleasure to guide you.
Look through these. I hope what you need is here.
Manufacturer's Codes
Setup Codes For Cable Boxes
Setup Codes For Cable Box/PVR (or DVR) Combos
Setup Codes For DVD Players
Setup Codes For DVD Player/VCR Combos
Setup Codes For PVRs (or DVRs)
Setup Codes For Satellite Receivers
Setup Codes For Satellite Receiver/PVR (or DVR) Combos
Setup Codes For TVs
Setup Codes For TV/DVD Player Combos
Setup Codes For TV/VCR Combos
Setup Codes For TV/VCR/DVD Player Combos
Setup Codes For VCRs
Please post back which one is yours with Serial number and Mfg.
Setup Codes for DVD Players such as Magnavox 0503, 0539, 0646, 0675, 0821,1268
Jun 05, 2011 | One For All URC4220 Remote Control
Necesito intruciones del este urc-3021bg1 para programar el televisor vizio.
From the Manual:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR, CBL/SAT,or TV). NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3 . Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
For VIZIO TV try one of the following codes: 1758; 0178; 10178; 627; 502
Mar 04, 2011 | One For All URC-3021 Remote Control
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
Feb 12, 2011 | One For All URC-4021 Remote Control
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
CBL/SAT,or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
Sep 12, 2009 | Sanyo DVW-7100A DVD Player/VCR
Remote code
Manufacturer Codes
LG/Goldstar 1, 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
That is the whole list from the manual
Dec 31, 2008 | LG RC897T DVD Recorder/VCR Combo
Magnavox DV220MW9 DVD Player VCR Logo
24 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
