We just bought a Kenmore Portable Air Conditioner 8,000 BTU 83086 NEED INSTRUCTION MANUAL thank you :-)
We just bought this Kenmore Portable Air Conditioner 8,000 BTU 83086 and there's no manual so can u plz help by finding one online??? I can't find one. It's the floor model (not window) we bought it at sears idk if that helps..
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Jul 05, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
Unit has been working but suddenly stopped and won't turn on. what is the problem?
Look for a little compartment of slot for a fuse or a reset button. Do you have the owners manual? That might give you some solutions as well.
Jun 17, 2014 | Haier Commercial Cool 8,000 BTU Portable...
Fan is making rubbing noise
Time to have an expert look at it as it might be a fan about to fail or something worse.
Aug 30, 2012 | Haier 8,000-BTU Commercial Cool Portable...
I have an older 8000 btu unit - i have no manual. its 98 outside - when i start up this unit , should i have it on hi- med - or lo ? if i run it too hard will i freeze it up?
If everything is clean and the unit is properly charged with freon then it should not freeze up and I would start it anywhere you want to as that just controls the fan speed. It's108 here. Best of luck and thank you.
Jul 22, 2011 | Kenmore 8,000 BTU Single Room Air...
Heating & Cooling Logo
288 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
