Question about Refrigerators
Water in bottom of fridge
Where is the drain tube for freezer located? How do you access it?
  • Refrigerators Master
  • 8,220 Answers
The drain tube in any refrigerator is located right below the tray inside the evaporation compartment. A tray below the coils is made so that it funnels out the water. A hole is in the lowest portion of the tray. Junk gets into the tray and blocks the water from draining and so it backs up and flows down to bottom of the frig.
To fix the problem ya gotta remove the service panel and unblock the drain. If ice is blocking the hole you can sometimes run a copper wire down in the hole attached to the defrost heater which is a neat trick. If you would love a service manual I have numerous oneswhich are easy to access at: appliancejunkgoogledrive.
Posted on Jul 17, 2013
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: water in bottom of fridge
In the back of the fridge way down low on the very bottom you will see the tube. If you think it is clogged. Take a spray bottle filled with very hot water and just a cap full of bleach. Spray it on the drain hole and this will rsolve your blockage issue
Posted on Feb 13, 2009
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Posted on Jun 02, 2009
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
heatman101
  • 43501 Answers
SOURCE: i think i have a frozen drain tube. water is
Yes you can get to it from the inside. There should be screws in the back towards the bottom of the freezer that wiil let you remove the bottom of the freezer compartment. Under tere you will see the drain hole and the freezer coils, alond with the defrost coil.
Then checkout this tip to help you make it so the hole won't freeze shut again...
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Apr 22, 2010
Ewave ERW121 puddles in bottom of fridge
If you have located the drain pan, look for a flexible tube that extends into it. That's the drain line. You should be able to trace the tube back into the freezer section and you will be able to clean it
May 21, 2013 | Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Water in the bottom of the freezer that freezes, then the water goes out the door and is messing up my floor. My fridge is a Frigidaire side by side model MRS26LGJ. Yesterday, I cleaned out the freezer and...
The defrost drain located behind the freezer back panel has gotten clogged. You will need to remove the panel to gain proper access to the defrost drain. After removing the ice build up you will have to also clear the tube using boiling water alittle at a time poured into the drain opening. this will open the tube up and gain proper flow again.
Sep 22, 2010 | Frigidaire Refrigerators
My drain tube is clogged and water keeps pooling on the floor of the refrigertor. I need help locating access to the tube, please.
Switch of fridge for at least 6 hours. Behind the fridge , usually mounted above the comperssor you will find a drain pan, above which you will find a tube which drains water from the freezer. Use a stiff wire ( straightened out clothes hanger) and push through until the blockage is cleared. Alternatively you can access the drain tube from the freezer end after opening the panel that houses the eveporator fan
Sep 12, 2010 | Refrigerators
Where and how can I clean the drain hose on the Frigidare Ref. Water draining in Freezer Bottom
the drain hose runs from the bottom of the fzr to the tray under the fridge. The easiest point to access it is in the fridge compartment there will be a ketch basin (a plastic piece that ketches water from the freezer) with a plastic tube attached to it. This tube is what you want to clean I use compressed air on the tube and to blow up into fzr. good luck
Aug 16, 2010 | Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Water leaking from bottom
Between your freezer section and refrigerator section there is a draintube that allows water to flow from the freezer to the fridge during defrost. You will need to remove the rear wall of the freezer to access the freezer part and the center console of the fridge if one is there. Once you have determined that tube is cleared of ice you will need to continue tracing where the water flows which is usually at the top of the fridge section in the rear center. It goes out the back wall there. Make sure thats all cleared and pour a small cup of water in the freezer part to be sure its clean. Observe the water flow all the way out of the tube to the lower part of your unit into the drain pan which is located at the very bottom or in the rear on top of the compressor.
May 22, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
My fridge is dripping water inside the fridge
If you have a frig with the freezer on top, I might be able to help. When you frig freezer goes into defrost,. It melts the ice on the coils in the freezer. The water from that process drains from the bottom of the freezer, down a tube to the bottom of the fridge. If that drain gets something in it and stops it up, the water will overflow and run into the fresh food section of your fridge. If you can locate this tube at the back of your fridge. You can blow into it. Notice if there is a restriction when you blow pressure in it. A lot of the times when you start to blow it will be hard to blow through it. Then what ever is in it will let go and blow out releasing the restriction. If this happens, you will need to take the back inside wall out of your freezer and locate what was stopping the tube up or it will end up back in the tube again.
Please rate this submission. Thanks!
Aug 19, 2009 | Kenmore Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
