Question about Refrigerators
Dm2852 refrigerator not cooling
My r.v. fridge does not run on gas? ive checked everything runs on ac power my pilot lights right up but there is no cooling at all inside fridge.help.......
HVACRH20
  • 237 Answers
SOURCE: refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Posted on Jan 02, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
I turned off the refrigerator and left the freezer door open so the coils and the vents could thaw out. The cold air was not getting to the refrigerator section because of ice blocking the vents.
Posted on May 06, 2008
wheelshot
  • 102 Answers
SOURCE: Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Posted on Apr 11, 2009
bobicehouse
  • 1524 Answers
SOURCE: Our Antique GE refrigerator doesnt run, there is
Probably the compressor relay Located in little black box on compressor.
Posted on Apr 22, 2009
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Why does My dm2852 works on electric, but not gas. It lights (small flame), but doesn't cool.
It is more than likely just a dirty orfice. It can be cleaned quite easily by soaking it in rubbing alcohol then blowing it out. Do NOT POKE ANYTHING THROUGH IT! 946177a3-e85b-4832-879e-b23434d529ef.jpg ArctiCold Refrigeration We keep it cold
Jul 22, 2014 | Dometic DM2852 Americana Fridge...
Rm2352 will not work on AC, pilot will light, but then will go out. No cooling
LP check for cobwebs in lines and good gas pressure ac check heater element if ok disconnect thermistor from back board run overnite if ok replace thermistor if not bad cooling unit replace
Jan 29, 2014 | Dometic RM2652 Refrigerator
Does not cool in either ac or gas
More information required
does the compressor run ? It's the black round object behind the fridge if it's not running check the defrost knob on the bottom rear corner of the fridge sometimes they get stuck
Jan 10, 2014 | Dometic RM2652 Refrigerator
I have an old RV with a dometic refrigerator which runs on gas, 120 or 12v. I have verified gas at the stove. When slecting gas the refirg clicks trying to ignight but the piolt holes are rusty. Behind...
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF This service manual should help you get it going.
If the pilot light will not light, you need to get that operational before you can get the gas portion working. So you might want to take the pilot light assembly off (make sure the gas is off) and clean it with a brass wire brush. Once you get the pilot light to lite, then it should warm the thermcoupler that will open the gas valve.
Sep 01, 2011 | Dometic RM2852 Refrigerator
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2193 Works on 120V, but not on gaz. I succeded in cleaning the burner jet and I get a flame. It ligth well now but the flame very small. The frig doesn't cool. Help ?
These fridges require that the control switches be in the correct position for the power source you want to use. If you try to operate the fridge on gas and have the electric 120V-AC switch on, all you'll get is the gas pilot light to stay lit. Also, when running on gas, the electric has to be off.
Here's a link to the manual for your unit. Print a copy and save an electronic one for future use, in case you lose your printout.
Hope having the manual helps you to get the fridge working on all the power sources you need! Best regards!
Jul 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
