Question about Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer
How to wire the 5 wire data cable nmea0183
What is yellow tx+ what is blue tx- orange rx+green rx-
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
Oct 30, 2016 | Radio Communications
Cat 5 cable
The normal color code is. Orange white, orange, green white, blue, blue white, green, gray white, gray. the wire using for network only 2 pair. That is 1,2,3,6. For normal telephone - use blue pair (4,5). For pabx system use. 3,4,5,6. Connection. You can use any Color code If both ends are same.
Jul 02, 2012 | Computers & Internet
I only want to know the meaning of the different colours of cables that are used in crossover cables?
the standard colours for CAT5(e) or CAT6 ethernet cable are:
green, green stripe
blue, blue stripe
orange, orang stripe
brown, brown stripe
the typical setup for an ethernet connection in an RJ45 (the crystal end with the connection tab towards you) is
2 green
3 orange stripe
4 blue
5 blue stripe
6 orange
7 brown stripe
8 brown
Wires 1 & 2 are used to transmit data from the PC to the router/modem (TX) and wires 3 & 6 are used to recieve information from the modem/router (RX). in this fasion, information flows along one pair or another and is expected to arrive at that pinout. the router/hub/modem takes care of the transition to the next cable or out to the internet.
In a crossover cable ONE end is configured as above, but the colours for wires 1, 2, 3, and 6 are exchanged so that when no hardware is between the two PCs/components the signal is transmited at wire 1 & 2 and recieved on pins 3 & 6 on the other system/component. the other colours are placed for backward compatibilitiy and other applications, such as power over ethernet.
following the standard above allows anybody familiar with RJ45 connections repair a connection with a standard colour code and pattern without having to see the other end. If you know you need to replace one end of a patch cable, you use the standard termination.
Oct 12, 2010 | Computers & Internet
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Cat5e Single Socket RJ45 Ethernet Network Face Plate
My preference is to use the T-568b if there is not already a standard where you are doing the installation at. The A and B are just different standards to terminate an ethernet cable.
TIA/EIA-568-A, T-568B RJ45 Wiring Standards
To answer your question..If you want a straight through connection you would use T-568B (or T-568A) at both ends of the cable.
T-568B T-568A
Pin Color Pin Name Color Pin Name
1 Orange Stripe Tx+ Green Stripe Rx+
2 Orange Tx- Green Rx-
3 Green Stripe Rx+ Orange Stripe Tx+
4 Blue Not Used Blue Not Used
5 Blue Stripe Not Used Blue Stripe Not Used
6 Green Rx- Orange Tx-
7 Brown Stripe Not Used Brown Stripe Not Used
8 Brown Not Used Brown Not Used
Dec 31, 2009 | Cat5e Cat.5E Connection Box (512114)
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
How do you wire the cat 5e multi jack? Which wires go where?
Hi tonybenjamin
Here are the pinouts for a regular fly lead (PC to Switch"hub") and for a cross over cable (PC to PC)
1. Fly Lead
Name Pin Wire Color Pin Name TX+ 1 White/Orange 1 TX+ TX- 2 Orange 2 TX- RX+ 3 White/Green 3 RX+ 4 Blue 4 5 White/Blue 5 RX- 6 Green 6 RX- 7 White/Brown 7 8 Brown 8
2. Cross Over
Name Pin Pin Name TX+ 1 3 RX+ TX- 2 6 RX- RX+ 3 1 TX+ RX- 6 2 TX- Extra Pins 4 4 Optionl Pins
(connected straight
to same pins) 5 5 7 7 8 8
Regards
Go-Tech
Dec 14, 2008 | Leviton Quickport 5G108 Category 5e...
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Cat 5 wiring issue
I know this is an old thread, but for the sake of helping someone else in the future, I just got off the phone with the Phillips Help Desk and this is the way they told me to wire it up the RJ-11 & RJ-45 combo jack I bought (PH60037):
  • RJ-45
  • Jack colors - CAT 5e
  • Blue - white/orange
  • Orange - Orange
  • Black - white/green
  • Red - Blue
  • Green - white/blue
  • Yellow - Green
  • Brown - white/brown
  • White - brown
  • RJ-11
  • White - white/green
  • Black - white/orange
  • Red - blue
  • Green - blue/white
  • Yellow - orange
  • Blue - green
He said it was the standard configuration used by the phone companies for some time.
Phillips Help Desk # for phones/PCs (800-233-8412)
Hope that helps someone else down the road.
Thomas
Apr 21, 2008 | Computers & Internet
Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer Logo
168 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
