Question about Sanyo Televison & Video
Tv turns off itself
I was watching tv and out of the sudden the tv just turn off .. i try to turn it back on but it wont ...
    Top Expert:
  • Sanyo Master
  • 75,462 Answers
Check its horizontal output section circuit, and replace damaged component/s. Contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Posted on Jul 17, 2013
silly girl
  • 513 Answers
SOURCE: TV turned off by itself and now it won't turn back on
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Could be several things- a 15 cent fuse, some solder joints that fail due to expansion and contraction of the circuit boards. Hard to say. Look for parts that look or smell burnt, might help you narrow it down. The fact that it stopped suddenly, with no gradual deterioration makes me think that something blew, and it's a matter of replacing it. No tube damage or anything more serious, just a local fuse or cap. let someone have a look Good luck
Posted on Jun 15, 2006
SOURCE: tv wont turn on
check and replace any components that r burnt out
Posted on Feb 13, 2007
premtech
  • 934 Answers
SOURCE: TV Turns Itself Off
That set is a CTC197 chassis with a common problem - flyback or more commonly referred to as the FBT...
The FBT is a high voltage transformer which delivers a great deal of voltage to the crt to light the tube. The FBT is RCA p/n# 237502 and a ring test can confirm its failure. Another shortcut technicians use is to unsolder the collector of the HOT and power the set. If it powers with up and has audio you're in business, just replace the FBT and it's recommended to replace R14704 its an 82k ohm- 1/2w resistor and C14710 a .01/1kv cap as well. I believe if you order these as a kit, (ie: original RCA FBT), the two other parts are included - but ask to make sure.
You might also check for continuity across E & B of the HOT with a multi-meter while you're in there and if you get any resistance at all the HOT is shorted also... Or for simple reliability just replace it anyway.
Hope this helps!
Bill
Posted on Nov 13, 2007
SOURCE: RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Posted on Dec 25, 2007
SOURCE: Turns off by itself!!!
The flyback transformer are damaged .
Posted on May 28, 2008
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
Tv will not come back on
Did you try turning the TV on with buttons on the TV itself and not the remote?
Dec 30, 2007 | Televison & Video
Sudden rainbow vertical lines, Loud squeel. wont turn off. Whats wrong?!
good first shut off the outlet for what is looking like this with your tv connection problems with the drain tube of images giving us the inside source for capacitors in a technical lead for the electronic exchange of capacitors and diodes for your device
Sep 06, 2012 | Samsung LN46A500 46 in. TV
My sony trinitro wont turn on, the stand by light flashes 4 times
the four flash is a signal, it means either faulty power supply or deflection circuit trouble.
Jul 27, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
ILO TV turns off by itself.
Is your sleep timer activated? Check your menu settings. Or maybe some kid with a universal remote turning it off? Try covering the remote sensor with duct or electrical tape and see if the problem persists.
May 26, 2009 | iLO 3200 32 in. LCD Television
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
Turnt itself off and now it wont turn back on?
More that likely its a heat sync issue and your CPU and GPU need to be reseated. email dwdpcrepair@gmail.com for more information
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
