My printer -X1185 prints the page with a 3 inch blank area
on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for
users to print on 8.5- x 11-inch pieces of paper. This becomes obvious
the first time you try to print a Web page. Content you need may get
chopped off by the right printer margin, whereas content you don’t
need, such as the site’s copyright information, will print on its own
sheet of paper. Fortunately, you can avoid such problems with a little
foresight.
Before printing any Web page, open Internet
Explorer’s File menu and select Print Preview. The current Web page
will appear on-screen exactly as it will print on paper. Scan the
preview carefully. If it appears that some content is chopped off by
the right margin, click the Page Setup button located directly to the
right of the Print button in the upper-left corner of the Print Preview
window. In the resulting Page Setup dialog box, adjust the left and
right margins so that each is set to 0.25 inches. The extra inch of
space you gain by resetting the margins should provide just enough room
to accommodate all of the content on most sites. Click OK to save the
changes and return to the Print Preview window.
Next, scan the
preview to determine which pages contain the content you want to print.
Take note of those pages and click the Print button in the upper-left
corner of the Print Preview window. Locate the Print Range heading and
select the Pages option. Type the number of the first page you want to
print in the From field and type the number of the last page you want
to print in the To field. For instance, if you want to print just the
first three pages of a Web page’s content, type 1 in the From field and
type 3 in the To field. If your browser doesn’t have To and From
fields, type the range of pages (such as 1-3) in the corresponding
field. Make sure your printer has paper and click Print.
