Question about Sharp Home Theater Soundbar System- Angled View - HT-SB60
Red light blinking repeatedly. No stand by mode atall
Trying to switch it on. Red light is just blinking repeatedly. I swithed it off and on again, it still blinks.
3 Suggested Answers
mbelectronic
  • 147 Answers
SOURCE: power light blinking RED after power outage
replace the power pcb,check the fuse on the
power pcb and see if that corrects your problem.if not replace the power pcb.go tp
shopjimmy.com to get the board.
Posted on Jul 29, 2009
  • 8457 Answers
SOURCE: Sharp lc52d64u power light blinks once, then power
Ur Main Tuner signal board is dead.Replaced that board will fix the problems.Tries Shojimmy.com,Ebay.com to buy a refurbish Tuner board.
Posted on Feb 17, 2010
What to do with red blinking ON/OFF button on philips mci500h 12
Internal Power supply and could be a shorted diode or a relay could be causing the flashing red light. Usually the red light indicates the System is in stand-by mode or not in stand-by. If when you used to turn it off there was a red light though not flashing, then that means it is in stand-by so in that mode your remote works on some older sets work and others it doesn't matter because the remote will always work. Unplug it for a half hour and try it and see if the light stops flashing. Might help to give more clues towards the fix.
May 15, 2014 | Televison & Video
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
Mar 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  1. Manually turn on device to be controlled.
  2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
  5. Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
  1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
  2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
  3. Press and release the "Code Search" button. The red indicator light goes off.
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
  6. Repeat again for the third digit in your code number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Jul 21, 2008 | Logitech MX 600 097855036162
PS3
it sounds like your power supply is faulty or you need to make sure all wires are in properly if that don't work leave it in stand buy mode for 12 hours do not touch it at all or you will have to do it all over again it needs the back up battery to gain more power let me know how you get on
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Sharp Home Theater Soundbar System- Angled View - HT-SB60 Logo
80 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
