We just bought Kenmore Portable Air Conditioner 8,000 BTU the one that sits on the floor (not window) and it did not come with a manual so if u could help it be appreciated THANK YOU
? 1:59
www.youtube.com/watch?v=kx1_1q4ByC8
Apr 19, 2015 - Uploaded by Denada Pinoy
In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
most window units use the condensation to help cool the condensor. some days little to any drainage. a slinger ring on outsde blade side throws water on coil and evaporates.
You CAN put it on the 3rd floor as long as you make sure it's completely secure. One thing I do recommend is building (or buying) a window unit shelf that sits outside the window and the air conditioner sits on it for extra support. The shelf is secured by the window frame.
There are many "how-to" guides to building a window unit shelf all over the internet.
