Question about Garden
I replaced both the fuel and primer lines when a small spring came out. Need to know where this came from and to put it back.
  • 112 Answers
If you pulled the carb apart it could be under the needle lever, if not maybe it was around one of the gas lineswhere they connect in the tank. not much info to go on
Posted on Jul 17, 2013
#1 Taper
  • 1040 Answers
SOURCE: need diagram on fuel lines on a 26 cc craftsman weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
rycgl
  • 1545 Answers
SOURCE: need to know the fuel line routing including the primer bulb.
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Look carefully at the 2 nipples on the carb. You can tell one is slightly larger than the other. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. completing the purge circuit. This info pertains to the Craftsman 32cc with Zama carb and may work on the 25cc model as well.
Posted on Jun 01, 2010
Testimonial: "local lawnmower shop told me wrong and I knew theoretically it wouldn't work The info gained here now makes sense of it all!"
rycgl
  • 1545 Answers
SOURCE: not getting fuel replaced primer and hoses and not
It's easy to mess this up as I've done it in the past. If the unit has an external purge bulb, the fuel line from the fuel tank that has the fuel filter on it goes directly to the carburetor...near the part of the carb that holds the fuel pump and has the grooved cover (where an inbuilt purge bulb would be). The other line coming out of the fuel tank goes to the purge bulb. The side of the carburetor that has the diaphragm and metering lever cover has the line going to the purge bulb. Remember, this is not really a primer...the purge bulb pulls air and old fuel out of the carb and when it does this, fresh fuel flows into it...and then the bulb pushes that air and old fuel back into the fuel tank. Hope this helps.
Posted on Jun 16, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
rycgl
  • 1545 Answers
SOURCE: trying to replace the fuel line and the primer
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Posted on Aug 07, 2010
I need to replace the fuel and primer lines. I need to know where to buy them and I can't remember which line goes where.
Home Depot sells a Ryobi/Homelite fuel line repair kit that includes the primer bulb, fuel filter and fuel lines. This is for a trimmer/blower with the bulb on TOP of the carburetor, not remote. If you like, you can get the necessary lines at any small engine shop (like lawn mower repair place). The line out of the fuel tank with the filter on the end goes on the side of the carb with the vent-hole in the cover. The other line that sends fuel Back to the tank (fuel return line) is connected on the other end under where the primer bulb is. I hope this helps. Post back if needed.
Sep 04, 2011 | Garden
There are two outlets on the primer bulb for fuel mine rotted away while my son had it . I need to know which tube goes to where when i replace it.
Ok...follow these instructions closely and you will know.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
May 17, 2011 | Garden
I'm trying to get an old weedeater/poulan 22" excalibur hedge trimmer running for my son. In the past someone has cut a fuel line going to primer bulb. I replaced that line and when I use the primer...
There are 2 different set ups for fuel lines on these 2 stroke carburetors. One has a remote primer/purge bulb and the other has the primer/purge bulb on top of the carburetor. Here are instructions on how both kind work and how to service them.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so If you have any more questions, please post back. I will see your comment and be glad to help you,
Apr 23, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
I HAVE A RYOBI VAC/BLOWER MODEL RGBV3100 THE FUEL LINES NEED REPLACING THEY ROTTED OFF NEED TO KNOW WHICH WAY TO ROUTE FROM PRIMER BUTTON TO CARB
Feb 18, 2011 | Ryobi Garden
I have a 32cc trimmer and I pulled the carbi and fuel tank off to replace all hoses. This model has a primer with three hoses. I do not know which hoses go to carbi and primer. Please help. Thank you,...
Dec 22, 2010 | Craftsman 25cc Gas Line Trimmer
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Replacing fuel lines on ryobi weed eater,need
Jul 10, 2010 | Craftsman Garden
Replacing fuel lines on poulan 2550 and dont know where they go.I have small and larger line into tank,primer bulb says tank and carb ,there are two ports on carb,2 on primer,and 2 into tank.
A typical fuel system and a couple of tips follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Filter in tank on small hose. Make it long enough to reach all corners of tank when moved, opposite end to carburetor. Small hose from carburetor to primer. Primer to tank (large hose) long enough to reach mid tank, nothing on bottom. Try the upper carburetor connection to the purge pump (air rises). Leave them both a little long and try it. If not correct swap them.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 07, 2010 | Garden
Primer bulb only holds suction, wont move fuel thru line
By "holds suction" this means that you can depress the primer bulb and it remains in the "pressed" position and/or does not reinflate (for lack of a better term)?
You need to determine if a blockage exists in either one of the fuel lines, or with the primer bulb itself.
First, drain your fuel tank. Do this into a clear mason jar or equivalent and inspect your fuel to see if it is full of debris since even very small pieces of grass, dust, dirt, etc... can cause problems. If so, then you need to flush your fuel tank and or lines.
Viewing the backside of the primer bulb, you can see several clear fuel tubing lines that lead from the primer to the carbureator and fuel tank..
Next, carefully remove these using a pair of needle nosed pliers (or by hand is at all possible) being very careful not to crush or tear the tubing.
With the clear tubing removed, if the primer bulb will press in and immediately reinflates back to it's relaxed position, then one or more of your lines are clogged by a small piece of debris. If the primer still does not relax, then it is blocked by a small piece of debris or needs to be replaced (pick one up at Lowes, etc...).
If you determine that your lines may be clogged, then I have had success clearing them with a can of WD-40 by sticking the red nozzle into the clear tubing (attempt to make a seal) and by pressing for a half-second or so. If you get flow, then let it rip for a second, then proceed to rinse your fuel tank again just for good measure (basically until you get nothing but clean gas...no debris).
Put it all back together and let it rip!
Jul 14, 2009 | Troy Bilt Tb70ss Gas Trimmer
Poulan Weedeater sst25 25cc engine fuel line
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
May 02, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
