Question about GE 98056 Keyboard
I need 2 new feet for my key bord an thenumber pad enter key for my key bord thanks
Stephen sholty 139 hisbuscus dr. Lafayette, Indiana 47909
    Scholar:
  • 127 Answers
Hi Stephen. It would be easier to replace it with another keyboard as those replacement parts will be hard to locate. I found a new keyboard using this search "GE (98056) Keyboard" and found one at amazon.com and one at ebay.com for around $40 range. If that is too much, you can use any USB keyboard you like instead, assuming you have an unused usb port left, that is.
Posted on Jul 17, 2013
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
I need Pfaff 139 instruction manual
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/d40760dedc7a000d852575f300570387/$FILE/Pfaff%20138-139%20.PDF
I just found this website with a clear version of the manual for Pfaff 138/139
Hope this helps you....it did me.
Jun 08, 2012 | Sewing Machines
Where is num lock key on Dell 5030
If there is no NumLock key then pressing the Fn (Function) buttonshould enable the number pad on the keys that have the Blue numbers onthem. On most laptops (dont know your model) there is a numlock key asthis allows the user to type numbers with two hands and not keep oneholding the Fn button. You would normally press the Fn button and theNumLock option to switch it on and every time you pressed the keys withthe numbers on it would use the number not the letter, pressing the Fnkey with NumLock on would normally allow the letter to be used withouthaveing to disable the NumLock.
This assumes of course that the normal letters are stamped with thenumbers on, if not it is most unusual, I don't think I hav eseen alaptop keyboard without numbers or the NumLock / Fn options. There areUSB number pads available that you can buy, these simply plug in to anavailable USB port and it is like an extension of your keyboard.
Please, please, please, we need to know how we aredoing! Please rate our help to you and leave us a comment so we could go onhelping people like you that need our assistance and expertise! Thank you and, Thankyou for using FIXYA! Bestregards,
Junior
Sep 18, 2011 | Dell Inspiron M5030 Laptop
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
How do you re-program the security code on a 2007
FORD KEY PADS
  • Enter permanent factory code
  • Press the 1/2 button within 5 seconds to enter programming mode
  • Within 5 seconds enter new code, doors will lock, unlock to verify code, this erases previous codes remotes will also need to be programmed. (MAYBE)
KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
NOTE-Some vehicles use 5 turns of the key instead of 8
Jun 05, 2010 | 2007 Ford Explorer Eddie Bauer
Where do i enter cheatson xbox 360 for Indiana
Sorry I haven't played the second Indiana Jones yet, but on the first game you entered the codes on the chalkboard. Maybe it's the same or something similar?
Feb 08, 2010 | Microsoft Xbox 360 Console
Keypad won't work anymore
Lets make sure you are programming it correctly, make sure the battery is new. Press and release the learn button on the motor. Within 30 seconds enter in the 4 digit code followed by the up/down button. The light bulb should flash once. If you can't get it to code in this way you will need to replace the keypad. Thanks BB
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Acer aspire 4315 keyboard functions
aspire 4315 key pad problem some keys not working i changed new key bord and again same problem how to solve this please help me
Aug 22, 2008 | Acer Aspire 5100 Notebook
GE 98056 Keyboard Logo
303 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
