Question about Fuel Pressure Regulator for 93-97 Ford Probe
Im getting fuel to my tbi but it wont stay running on my 1985 ford ltd crown victoria
I switched from my in take fuel pump to a inline fuel pump and it just wont stay running im getting fuel to my TBI but it just wont stay running it seems like it's just not getting enough fuel what would be wrong with it
  • 24 Answers
Check fuel pressure if good, inspect injectors
Posted on Jul 24, 2013
I'M NOT GETTING FUEL TO THE INJECTORS ON A 85 CROWN VIC . THE FUEL PUMP AND THE RELAY HAVE BENN REPLACED WHATS THE NEXT STEP/
You will only get fuel at the injectors when cranking, the pump wont run(Usually) with just the key on. This is to prevent the pump running in a crash and feeding the engine.
May 18, 2014 | 1985 Ford Crown Victoria
1985 ford crown vic ltd 352 200k miles been running good burns NO oil.\r\ndriving at night engine shuts down. I turn lights off, wiggle turn signal switch and it starts again. Once I was making a right...
I dont see if the turn signal light has to do any thing with the engine shutting off, make sure the IAC idle air control valve is working, air filter is good, fuel filter is good and IF your vehicle has a power steering pressure switch then that could be causing it but with 1985 Crown Vic I dout it.
Feb 27, 2011 | 1991 Ford LTD Crown Victoria
I own a 1985 ford LTD Crown Victory and Iv been looking for 4 god damn hours for the fuse diagram because I need to know which fuse goes to the Fuel Pump. Iv got to change the fuel filter and all I can...
the fuel pump is control with a fuel pump relay if the system has fuel injection.a fuel pump relay turns on for 3to 5 seconds and turns off unles the engine is running.Older Ford models also have a fuel cutoff if the car is in a collision . but if you slam the door or hit a bump it will also cutoff. the switch is black with a white button on top of it and I think it is located under dash on passenger side ,behind the kick panel close to the door..if you push on button and
it clicks you have found the problem.Otherwise I would suspect fuel pump inside fuel tank.If thats the case sometimes you can tap on the tank a few times and make that part work.good luck
Feb 16, 2011 | Ford LTD Cars & Trucks
I have a 1985 Crown Victoria Station Wagon with a 302 tbi unit and the car stays on fast idle till you turn the A/C on , then it kick's down . If you turn the A/C off it goes back on fast idle . What's the...
There should be a solenoid on the throttle body that kicks the throttle open when the a/c is turned on to keep RPM's up.That solenoid might be faulty or the wiring going to it.Possibly the switch for the a/c also, but check the other things first.
Jan 31, 2010 | 1985 Ford Crown Victoria
1985 crown victoria stalls out
Why not hook a fuel pressure gauge up to it & see what the pressure is ?? Am I missing something here?
Aug 31, 2009 | 1985 Ford Crown Victoria
HOW TO REPAIR 1990 CROWN VICTORIA THAT JERKS WHEN GOING UP A INCLINE. THERE IS A TRANSMISSION FLUID LEAK.
need more info it could be fuel pump as well as the transmission make sure trans. fluid is on the right level
Jul 09, 2009 | 1990 Ford LTD Crown Victoria
Fuel Pressure Regulator for 93-97 Ford Probe Logo
88 people viewed this question
Top Motorcraft Vehicle Parts & Accessories Experts
Bill Boyd
Todd Arndt
Todd Arndt
Jim Beaty
Jim Beaty
Level 1 Expert
Are you a Motorcraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
